CAM question
Old Feb 1, 2004 | 04:17 PM
Clown Puncher's Avatar
Clown Puncher
Default CAM question
what problems if any would a COMP 268H cam have / cause with a stock converter . My car is a 355 with around 340 HP and stock 3 speed. ( TH400) I think. Does anyone know the Stock stall also?
Old Feb 1, 2004 | 05:59 PM
Les's Avatar
Les
Default Re: CAM question (Clown Puncher)
Comp Cams states that the 270H is the biggest cam that you can still use the stock converter with, so you will be fine with the 268H. Stock converter should be somewhere around 1800-2000 stall if I remember right.
Old Feb 1, 2004 | 10:33 PM
78 Vette's Avatar
78 Vette
Default Re: CAM question (Les)
:iagree:
Old Feb 1, 2004 | 11:17 PM
comp's Avatar
comp
Default Re: CAM question (78 Vette)
i'm lookin' into the 62 or 68 for my truck you should be good
Old Feb 1, 2004 | 11:39 PM
Corey_68's Avatar
Corey_68
Default Re: CAM question (comp)
I ran the 268 in my 327 and LOVED it, great low end and midrange and had a nice rumble at idle. :thumbs:
Old Feb 2, 2004 | 10:49 AM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Are you talking about the 268H or XE268H?? Big difference!
To CAM question
