Gear ratio calculator ???
Old Feb 3, 2004 | 01:47 PM
stingraymax's Avatar
stingraymax
Default Gear ratio calculator ???
Hi, I am looking for an easy to use and good gear ratio calculator, I know it saw one here some time ago but I can't find it anymore :confused:
I am planning on installing a 200R4 and would like to find out what the best rear end gear would be for me ...
Stef
Old Feb 3, 2004 | 03:59 PM
JJMURFS's Avatar
JJMURFS
Default Re: Gear ratio calculator ??? (stingraymax)
Here is one I've used before:
http://www.quiknet.com/~ke6vut/rpmcalc.html
Hope it helps you :cheers:
Old Feb 3, 2004 | 04:20 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Check here ;)
http://www.forcedpsi.com/Calculators.html
Old Feb 3, 2004 | 10:08 PM
Glensgages's Avatar
Glensgages
Write this down on a piece of paper, & keep it with your pocket calculator...
If you know the height (in inches) of your tire;
RPM x .9 (if non-locking converter or stick-shift) x .006 x 1/2 TH (tire height {in inches}) divided-by MPH = gear ratio needed to run THAT MPH at THAT RPM with THOSE size tires.
If you run an OD transmission, you must divide THAT # by the OD ratio (700R4 is .7; I'm not sure about the 200-4R).
In my '82 (before the gear-swap to 3.73:1), I'd turn 1500 RPM @ 60 MPH (verified) with 27" tires, a lock-up converter, & 2.87:1 gears.
Thus:
1500 (RPM) x .006 x 13.5" div/by 60 (MPH) div/by .7 (OD) = 2.892, or very close to the 2.87:1 gears in the car.
'Old-time' racers keep this formula handy...
Old Feb 4, 2004 | 12:42 PM
markdtn's Avatar
markdtn
Default Re: Gear ratio calculator ??? (Glensgages)
I think there is one on http://www.bowtieoverdrives.com
To Gear ratio calculator ???
