Vacuum System Poll
Old Feb 3, 2004 | 03:17 PM
l2vette's Avatar
l2vette
Default Vacuum System Poll For 68 thru 72 Vettes only
How may of you C3 owners have your Vacuum System working ????
:cool:
[Modified by l2vette, 12:33 PM 2/3/2004]
Old Feb 3, 2004 | 03:29 PM
gerry72's Avatar
gerry72
Default Re: Vacuum System Poll (l2vette)
You need to split this at 68-72 and 73 and later since the wiper system was dumped in 73. With some understanding of the operating and control systems and a bit of work, it can be done.
Old Feb 3, 2004 | 03:35 PM
l2vette's Avatar
l2vette
Default Re: Vacuum System Poll (gerry72)
Thanks...........I made the change, but who knows if the first four who responded have a 68 to 72!!
Old Feb 3, 2004 | 03:51 PM
1979toy's Avatar
1979toy
The first person to respond has a '79. :D
Solid LT1's Avatar
Solid LT1
I bought a 72 coupe several years ago to "MAKE MONEY" on (I made about $500 for 250hrs of labor, GREAT RETURN!) I finished getting the vacuum system working about 1AM on morning, then realizing my lovley wife was driving my 72 LT-1 to work the next day, I remebered the wipers didn't work on it and there was a chance of RAIN! 2.5 HRS later I had tracked down the problem to an open resistor on the back of the winshield wiper motor causing the system to not function and fixed it! I really made great money on that 72 coupe! ($2.00 an hour!) never again! My winshield washers on my LT-1 do not work, the resivior has been replaced by a 2qt Accusump system! but all other functions work!
[Modified by Solid LT1, 5:26 PM 2/3/2004]
Old Feb 3, 2004 | 03:57 PM
mrvette's Avatar
mrvette
Default Re: Vacuum System Poll (Solid LT1)
At one time it all worked 100%, but then I got bored, and put in a intermitant wiper on that door system the '72 has......then hit a deer which wiped out the headlights, so in went a set of fixed Eckler trays....
now I want to make a pair of operating lo profile lights....
maybe next year, maybe never....who knows...???
GENE
Old Feb 3, 2004 | 04:05 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Vacuum System Poll (mrvette)
Got a 73 and it seems to be working properly :smash: :cheers:
Old Feb 3, 2004 | 04:17 PM
ejr76's Avatar
ejr76
Default Re: Vacuum System Poll For 68 thru 72 Vettes only (l2vette)
My 76's works fine, except once in a while the hose slips off the connector.
Old Feb 3, 2004 | 04:37 PM
Steve Straus's Avatar
Steve Straus
Spent a few hours on the wiper door. Mine is 100%
Old Feb 3, 2004 | 06:22 PM
SAC's Avatar
SAC
Default Re: Vacuum System Poll For 68 thru 72 Vettes only (Steve Straus)
My vacuum system works great since I bought it. One of the wipers doesn't stow all the way and the wiper door gets stopped from closing completely flush. I have to get out and push the wiper the last few inches down for it to completely shut. Oh well, one more thing to tinker with.
Old Feb 3, 2004 | 06:26 PM
71'AirStrike's Avatar
71'AirStrike
yes mine work.. they do "wink" when I start the car, or travel at hish speed. but they popup up when needed.
chad
Gordonm's Avatar
Gordonm
Default Re: Vacuum System Poll For 68 thru 72 Vettes only (SAC)
My 72 has been working good for the last 5 years. I don't drive in the rain and rarly at night so not much call for it. I give it a work out about 2 times a year just to make sure it all works.
Old Feb 3, 2004 | 06:27 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I got the headlights to work and the wipers to work, just not at the same time. :lol: The wipers will work only if I open the door for them---they're shy I guess. :lolg: I think I need an actuator.
Old Feb 3, 2004 | 06:28 PM
Corey_68's Avatar
Corey_68
Default Re: Vacuum System Poll For 68 thru 72 Vettes only (1970 Stingray)
Mine works, but did replace the lines about 2 years ago. :thumbs:
Old Feb 3, 2004 | 08:29 PM
PRNDL's Avatar
PRNDL
Default Re: Vacuum System Poll For 68 thru 72 Vettes only (Corey 68)
let's see...... my vac advance works, my wiper door works, but the wipers don't work :(.... my headlights pop up... my vac can is bypassed, so I guess my vacuum system mostly works! :) MJ
Old Feb 3, 2004 | 08:51 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Vacuum System Poll For 68 thru 72 Vettes only (MNJack)
everything but the wiper door...which is eliminated. :cheers:
Old Feb 4, 2004 | 06:35 AM
Mystery Machine's Avatar
Mystery Machine
I ain't got none of it working! :crazy:
I am in the process of going to elec. motors for my headlights, after that all vacuum goes away for me! :hurray:
To Vacuum System Poll
Old Feb 4, 2004 | 09:30 PM
wayne_69_427's Avatar
wayne_69_427
Everything is up and running :thumbs:
Old Feb 4, 2004 | 11:59 PM
Stoge's Avatar
Stoge
My headlights are slightly slow, and my climate control system always blows out of the lower vents. Otherwise, it works well. My ThermAC motors work correctly, power brakes work well, etc.
Old Feb 5, 2004 | 12:52 AM
stickboy's Avatar
stickboy
Mine works just fine :cheers:
