Ignition module - points replacement - one wire set-up?
Old Feb 3, 2004 | 07:42 PM
74FLCONV's Avatar
74FLCONV
Default Ignition module - points replacement - one wire set-up?
Recently someone posted the website for a points-replacement ignition module that utilized one wire. Cost was appx. $139.00. I do not believe it was Petronix or Ignitor. Can't seem to find the post in "search".
:confused: :confused: :confused:
D. Ocean
Miami, FLA
Old Feb 3, 2004 | 08:47 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: Ignition module - points replacement - one wire set-up? (74FLCONV)
less than $139. Is this it?
http://cranecams.com/?show=xri
Old Feb 3, 2004 | 08:50 PM
Paul L's Avatar
Paul L
You will find it here.
http://www.lectriclimited.com/
Old Feb 3, 2004 | 10:19 PM
74FLCONV's Avatar
74FLCONV
Default Re: Ignition module - points replacement - one wire set-up? (paul67)
That's it...thanks!
D. Ocean
Miami, FLA
To Ignition module - points replacement - one wire set-up?
