Would a engine wiring harness from a 66 work?
Old Feb 4, 2004 | 08:28 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default Would a engine wiring harness from a 66 work?
On my 68??
I realy need the help.
Old Feb 4, 2004 | 09:08 PM
wacked's Avatar
wacked
Default Re: Would a engine wiring harness from a 66 work? (wackedvette)
Any one? :cry :cry :cry
Old Feb 4, 2004 | 10:02 PM
Corvettes White's Avatar
Corvettes White
Usually they change every year, I would not even try.
George
Old Feb 4, 2004 | 10:10 PM
wacked's Avatar
wacked
Default Re: Would a engine wiring harness from a 66 work? (999)
This is the harness, http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBBI%3AIT . I receved a email from them saying its 66-68.
Here is the email--------------------------------------------------
IT IS PROBABLY 66 TO 68 BECAUSE OF THE PORCELAIN CUT DOWN ON THE IGNITION..........GEORGE
[Modified by wackedvette, 3:11 AM 2/5/2004]
Old Feb 4, 2004 | 11:35 PM
mapman's Avatar
mapman
Would a engine wiring harness from a 66 work? On my 68??
Those harnesses are approaching forty years old. I would get a new harness from Lectric Limited and save yourself a lot of pain and suffering.
The insulation on my 1980's wiring harness was beginning to crack. The LL harness was an exact replacement. The harness from the 66 will have it's own problems with deterioration in addition to the physical fit differences between the C2 and C3.
Old Feb 4, 2004 | 11:53 PM
Older Than Dirt's Avatar
Older Than Dirt
Default Re: Would a engine wiring harness from a 66 work? (mapman)
:iagree: I think I would opt for a new harness. Chances are that ebay one is some junk his grandfather threw in the corner years ago. :lol:
Old Feb 4, 2004 | 11:55 PM
wacked's Avatar
wacked
Lectric Limited, I contacted them. There web site says that thay referbish(sp) harnesses. I was told that thay dont.
Old Feb 5, 2004 | 06:03 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Buy a new harness. I wouldn't even consider messing with an old harness. I've bought a few old hanesses in my time, but I have just used them for parts, connectors, clips, etc. Chuck
Old Feb 5, 2004 | 07:07 AM
markdtn's Avatar
markdtn
Default Re: Would a engine wiring harness from a 66 work? (Chuck Gongloff)
quote:Buy a new harness. I wouldn't even consider messing with an old harness. I've bought a few old hanesses in my time, but I have just used them for parts, connectors, clips, etc. Chuck
:iagree: :iagree: Don't risk burning up the car to save a few bucks. Buy a new one and you should be good for another 30 years. Try Last Detail as a good source for Lectric Limited.
Old Feb 5, 2004 | 08:29 AM
Edzred72's Avatar
Edzred72
:iagree: :yesnod: I tried repairing a chopped up Bubba'd old harness...not worth the time or effort. Spent a good 24hrs total trying to make it right. Even had electrical engineers check my work. According to every diagram I had, it was perfect. From the fuse box all the way to the right marker light. Power, continuity, perfect soldered splices etc...Still didn't work right. Spent the $155 from TDL and TA-DAAAAA!! LIGHTS!!!!! Buy new, it's soooooooo much easier and safer.
Eddie
To Would a engine wiring harness from a 66 work?
