PPG Paint Questions
Old Feb 4, 2004 | 08:52 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default PPG Paint Questions
OK, my car is going for paint this weekend. It is going to be black. My painter and I have talked about the process more than once. He asked me if I wanted Base Coat/Clear Coat or base and clear mixed. What is the difference and why choose one over the other?
Any help would be greatly appreciated.
Old Feb 4, 2004 | 08:56 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: PPG Paint Questions (Eddie 70)
I really doubt that PPG recommends mixing the basecoat abd the clear coat.
the base coat is a noncatalized polyurethane while the clear is catalized.
Usually tha clear coat is seperate and provides protection for the basecoat.
It's probably cheaper tho to mix them and spray it on one shot. But personally :U
Base coat, then three coats of clear, wet sand then buff...thats how you do it.
Old Feb 4, 2004 | 09:02 PM
motown 71's Avatar
motown 71
:iagree: Mixing the base coat and clear coat togrther is not the way to go.....
It is call "BASE" coat for a reason !
I'd be leary of any paint shop suggesting such a pratice :skep:
Old Feb 4, 2004 | 09:10 PM
LFZ's Avatar
LFZ
I think your painter is referring to the PPG concept DCC urethane paint..in which for the added depth and wet look, you mix the base urethane with the clear urethane. I know this, because its awesome paint, and i just painted my 69 with it. Great stuff, very durable and wet looking.
Old Feb 4, 2004 | 09:18 PM
motown 71's Avatar
motown 71
Default Re: PPG Paint Questions (Redshark6974)
Always looking to learn redshark !!
If your paint system were designed to work in this manner would it not be THEE way to squirt it without "options" ?
Old Feb 4, 2004 | 09:28 PM
LFZ's Avatar
LFZ
Default Re: PPG Paint Questions (motown 71)
motown...we use acrylic urethane paint on choppers and lots of show cars mostly. Sometimes we just urethane it...no clear...still looks good, depends on the color, but for colors like black and red...for added depth, you mix 1 part clear, and 1 part base urethane. Remember....some people call this base coat/clear, in which it is....but in actuality, the base is still shiny with urethane.
Old Feb 4, 2004 | 09:30 PM
motown 71's Avatar
motown 71
Thanks for splanin !!
When ya stop learnin' ya stop breathin'
:flag
Old Feb 4, 2004 | 09:31 PM
Eddie 70's Avatar
Eddie 70
Is one way better for durability? He did mention, like you said, the color was deeper with the base mixed with clear.
Old Feb 4, 2004 | 09:38 PM
LFZ's Avatar
LFZ
PPG DCC urethane is durable as is....more durable than standard base coat clear. I don't know if it makes a difference whether way is more durable, i would just highly recommend it...I would not put nothing but the best on my car, so coming from a personal painter..you will be very pleased :thumbs:
Btw Eddie, its very expensive paint...if you don't mind me asking...how much is paint job going to set you back?
motown 71's Avatar
motown 71
In my rookie opinion...... look at something......now look at it through water.
or use glass like a window paine........
Again........the opinion of a rookie. :crazy:
Old Feb 4, 2004 | 09:42 PM
black77's Avatar
black77
:iagree: you painter is talking about single stage urethan (dcc) as compared to base coat clear coat as a painter i have used both product there great products (look great) !!!! i personaly prefer bc/cc it last longer here in the texas sun.
Old Feb 5, 2004 | 08:08 AM
ettev's Avatar
ettev
This goes all the way back to the old enamel systems. I remember seeing one of our friends putting clear in the final application coats of enamel. When asked why, he said "just wait and see". I did, and wow! Even with the old enamels this really made a big difference.
Can't speak to mixing base coat and clear coat though. Sorry.
Old Feb 5, 2004 | 11:06 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
its called a Kandy paint job. It is more difficult to apply because the paint is transparent to some extent, so your spray pattern must be very consistant to avoid streaking and insure uniformity.
They are supposed to look killer though. I am going to try doing it on my car this spring.
Old Feb 5, 2004 | 11:08 AM
LFZ's Avatar
LFZ
Default Re: PPG Paint Questions (turtlevette)
sorry, this is not a kandy paint job. there is no undertone/base that needs to be applied for transparency for the kandy color. Kandy painting is very difficult and time consuming and is a completely different process.
Old Feb 5, 2004 | 11:26 AM
turtlevette
Isn't the semi transparency of the paint by mixing with clear similar to the kandy process? Agreed that kandys need some sort of base color, but a primer coat would serve that purpose.
I have also seen different ways to do the process, some involving a pearl in a toatally separate coat and others involving just a base coat, a translucent coat and a clear coat.
If you have experience in this area i would love to pick your brain.
Old Feb 5, 2004 | 11:38 AM
LFZ's Avatar
LFZ
turtle, the kandy process involves spraying numerous different coats to bring out a true kandy color. A few months ago, my fellow painting buddy painted a ChevyII Kandy Brandywine...we primed the car, shot a coat of Gold base, then layed a coat of the transparent kandy, which was wine colored, then shot the clear. The key to all this is to get the primer as smooth as possible. We wet sanded the primer with 800, got it slick, because kandy is a highly metallic paint...its very important to get the kandy on even throughout the car..its a process thats for sure.
PPG DCC urethane is a totally different. You spray a sealer in which the primer is mixed with the base urethane, then spray on the urethane, and for kicker, you mix the clear with the base and shoot it last. Comes out looking thick and wet.
Old Feb 5, 2004 | 01:27 PM
lbell101's Avatar
lbell101
There is newer (reletively) HOK "Kandy Koncentrates" that are added to the first coats of clear to produce a Kandy like appearance. They are mainly used in the jamb areas to match the Kandy exterior without so many coats. I know of a few painters using Koncentrates on overall jobs.
Of course this isn't what is happening in this case. I agree that mixing base with clear isn't the way PPG says to do it.
Larry
Midwest Paint
To PPG Paint Questions
Old Feb 5, 2004 | 02:07 PM
Corey_68's Avatar
Corey_68
Default Re: PPG Paint Questions (lbell101)
Your paint was reffering to a "Single Stage paint" vs base coat/ clear coat. The single stage is often cheaper but the BC/CC is the way to go. :yesnod:
Old Feb 5, 2004 | 09:38 PM
black77's Avatar
black77
Default Re: PPG Paint Questions (Corey 68)
:iagree:
Old Feb 6, 2004 | 02:02 AM
GDaina's Avatar
GDaina
Default Re: PPG Paint Questions (black77)
The same process can be applied with laquer...the last coats mix laquer with clear..and final coats straight clear. Awsome depth. only one problem, touch ups are nearly impossible.
