Has anyone seen a vin # like this?
Old Feb 5, 2004 | 09:09 AM
JBR's Avatar
JBR
Default Has anyone seen a vin # like this?
1982 t-top vin # 1G1AY8787C5121244 I looked at it twice can't figure it out. Any ideas :cheers:
Old Feb 5, 2004 | 09:46 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Has anyone seen a vin # like this? (JBR)
It's a valid 82 VIN from the looks of it, they started using 17 digit VINs from 82 -up
What's wrong with it?? The check digit??? (the 9th digit is the check digit)
My 82 VINis 1G1AY8780C5123904
[edit eddie thanks for letting me know I made a mistake here, 9th = check digit, not 8th)
[Modified by Twin_Turbo, 7:45 PM 2/5/2004]
Old Feb 5, 2004 | 08:18 PM
munday's Avatar
munday
well it was made in america...
the new chevy aveo starts the vin with a "K"
KOREA!!!! they are made at the old daewoo plant
Old Feb 5, 2004 | 08:28 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Has anyone seen a vin # like this? (munday)
According to the Black Book the second 7 should be a 6. This is what I think the problem is.
Edit-I miss counted on the second seven. Marck is correct.
[Modified by Eddie 70, 9:02 PM 2/5/2004]
Old Feb 5, 2004 | 08:35 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Has anyone seen a vin # like this? (Eddie 70)
the black book just lists it as a 6 but it can be anything, it's the check digit mine is a 0:
1G1AY8780C5123904
Old Feb 5, 2004 | 08:58 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Has anyone seen a vin # like this? (Twin_Turbo)
your VIN checks out correctly in carfax so the check digit is correct. (7 records found)
What's the problem with the VIN? The 17 digit vin is built up like this:
1 = USA
G = General Motors
1 = Chevrolet division
A = restraint system (non passive seat belts)
Y = Corvette
8 = body style (coupe, 0 for Collector edition)
7 = body style (with above one makes 87 = coupe, 08 for a Collector = hatchback)
8 = Engine : Twin TBI 5,7L OHV L83
7 = check digit
C = year (C = 82 D= 83 - non existent, E = 84...and so on)
5 = assembly plant
1= a filler because prod # starts at 100001
21244 = prod number
Old Feb 6, 2004 | 05:47 AM
Twin_Turbo's Avatar
Twin_Turbo
Worse yet, deawoos will be badged chevrolet in Europe shortly, there's not one appealing car in the entire deawoo line up. What was GM thinking??? I tell you, a reorganization is needed in the top ranks at GM
Old Feb 6, 2004 | 06:08 AM
JBR's Avatar
JBR
Thank you for all your help. I was more used to pre 80 vin # and never saw one like that. This is the car my friend bought, that I asked the cross fire ?s on. Still not running. Will be soon The weather has been so bad to do anything. What does "7 records found" mean and how can I see the records? :cheers:
Old Feb 6, 2004 | 10:48 AM
Twin_Turbo's Avatar
Twin_Turbo
there are 7 records in the carfax database, they may be nothing or they maybe some interesting info. You need to subscribe to look at the details or ask someone that has a subscription (for a few days). Min returned 2 non meaning records whereas that does not represent what actually happened to the car (wrecked, stolen, chop shop,....)
To Has anyone seen a vin # like this?
