Intake/Carb
Old Feb 5, 2004 | 01:33 PM
AV8RSVT's Avatar
AV8RSVT
Default Intake/Carb
I have A "72" 350 4-sp. I want to install A Weiand STEALTH and A BG Speed Demon Mech Sec (no choke) 750. Will this fit under the stock small block hood with A drop base air cleaner? How much drop for the air cleaner? Or how about An Edel perf RPM manifold? Isn't the stealth shorter than the performer RPM? What about Vacuum ports on the BG to run all my assecories? Please help I want to start collecting my parts soon. THANK YOU EVERYBODY!!
Old Feb 5, 2004 | 03:43 PM
AV8RSVT's Avatar
AV8RSVT
Default Re: Intake/Carb (AV8RSVT)
ttt ANYONE :steering:
Old Feb 5, 2004 | 09:24 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
both combinations should fit with a radical drop base.. I run a Victor Jr (which is approx. as high as a Performer RPM) with a 1/2 inch spacer and still have 1/2 inch hood clearance left... The drop base that I use is a 1 1/4 inch drop base with a 2 1/4 inch air filter...
Old Feb 6, 2004 | 02:24 AM
AV8RSVT's Avatar
AV8RSVT
Default Re: Intake/Carb (GrandSportC3)
Thank You very much grandsport Nice ride by the way!! :cool: Anyother opinions :steering:
To Intake/Carb
