73 Hood Repair
Old Feb 8, 2004 | 09:36 AM
73 Vet's Avatar
73 Vet
Default 73 Hood Repair
Has anyone made repairs to the underhood area where the hood support is mounted? Mine is cracked there.
Old Feb 10, 2004 | 02:51 PM
Ron71's Avatar
Ron71
Default Re: 73 Hood Repair (73 Vet)
I had a small crack on the bottom of the hood on my 74. I used a dremel tool to rough up the area about 2 inches around the area to be repaired and then used a small sanding wheel attachment with the Dremel tool to make a groove out of the cracked line. You do not want to sand all the way through, but enough to make a kind of v shape to hold some fiberglass and resin. I then bought a fiberglass kit with the glass fibers, resin, etc. Soak the fiberglass in the resin, spread over the damaged area, and press out any air bubbles with a body filler plastic spreader. You will want to build this up with a few layers and an extra layer or two directly above the portions that were V'd out. Be sure to press out any air bubbles. Allow the fiberglass to cure and then sand smooth. My repair turned out great and absolutely seamless. I then gave it shot of black primer followed by some semi flat paint.
Ron
Old Feb 10, 2004 | 04:35 PM
73 Vet's Avatar
73 Vet
Default Re: 73 Hood Repair (Ron71)
Thank you. Mine is actually cracked through....could I use this method by "roughing up" a 6 to 8 inch section and applying the fiberglass?
Old Feb 10, 2004 | 04:48 PM
terry82's Avatar
terry82
i did the same repair on my 82 ,the dremal is the tool of choice .
Old Feb 11, 2004 | 03:02 PM
Ron71's Avatar
Ron71
This method will definitely work. Make sure that you rough up the surface, and make a v on the full line of the crack. If you get the Speed channel, they have been running a series showing a full restoration of a C3 and they used the same method. Grind out any of the loose strands, replace with several layers of fiberglass mat (Don't confuse the mat with the fibeglass cloth). You can easily see the difference when comparing the two. One is just like the original material and very fiberous, whereas the other pretty much looks like a woven cloth.
If you get done sanding and you still have some spots that are rather low, simply rough up the surface and apply some more mat and resin and be sure to press out the air bubbles and you should be all set.
To 73 Hood Repair
