68-75 hardtop window trim removal ?
Old Feb 8, 2004 | 05:03 PM
monzared69's Avatar
monzared69
Default 68-75 hardtop window trim removal ?
This may seen like a silly question but how do you remove the rear window trim ?
I bought a blk vinal top kit from Al Knoch and need to remove the trim.
Also has anybody converted there painted top with this kit ?
Thanx Mark :auto:
Old Feb 9, 2004 | 11:24 AM
Chuck-75's Avatar
Chuck-75
Default Re: 68-75 hardtop window trim removal ? (monzared69)
I had this same question?, I just looked at my (Mid America) Assembly Manual and on sheet 19/ c01-c12 theres a pitcure of the rear hardtop trim, theres clips going around ,but in the top and bottem center it looks like where the trim meets and theres a 2 inch clip overlaping them?, there might be a screw holding down that molding?, not sure, these manuals are sometimes hard to read. if yr E-Mail is on this site Ill send ya a copy of this page.... Chuck-75... :seeya
Old Feb 9, 2004 | 02:41 PM
crf311's Avatar
crf311
Just did it on my hard top. there is a tool you can get from a paint supplier. It is hard to describe but they will know what you are looking for. It only cost about 5-6$ . It slides under the molding between the glass and molding catches on the clips , and with a little pry it releases the molding. DO NOT TRY AND USE A SCREWDRIVER or anything else. Get the tool, and it will take you about 5 min. Good Luck. :cool:
To 68-75 hardtop window trim removal ?
