Fuel line question.
Old Feb 9, 2004 | 10:28 AM
stingraymax's Avatar
stingraymax
Default Fuel line question.
I noticed a while back that I had a fuel leak at the back of the car.
Today I took a closer look and it seems to be one of the rubber lines comming from the top of the sending unit to the steel lines on the frame.
Now I know the best way would be to lower the tank but I'm having space problems, so now I was looking and I see that I can unscrew the two hoses thru the gas lid and you can feel where they connect to the steel lines on the frame.
Does somebody know if I could replace these rubber hoses without lowering the fuel tank ??
Old Feb 9, 2004 | 11:03 AM
Tom73's Avatar
Tom73
Default Re: Fuel line question. (stingraymax)
Remove the spare tire and tire carrier and you should have access. If not may have to lower the muffler/tail pipe to get clearance. Not a hard job, just takes a bit of time for disassembly and reassembly :)
tom...
Old Feb 9, 2004 | 12:34 PM
SCCACFC's Avatar
SCCACFC
Default Re: Fuel line question. (Tom73)
:iagree:
To Fuel line question.
