How difficult is it to remove the A/C?
Old Feb 9, 2004 | 01:04 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default How difficult is it to remove the A/C?
I have a 69 A/C coupe but the A/C has not worked in years. Since I haven't missed it I was going to remove the components (and naturally, save them for the next owner).
What exactly should I remove and how difficult a job is it?
[Modified by 6t9l4t6, 6:04 PM 2/9/2004]
Old Feb 9, 2004 | 01:29 PM
LT-1 Larry's Avatar
LT-1 Larry
Default Re: How difficult is it to remove the A/C? (6t9l4t6)
DO NOT lay under the car and bleed the freon out of the system. I almost lost a cousin that way.
Old Feb 9, 2004 | 01:42 PM
Shark Racer's Avatar
Shark Racer
Remove the compressor, condensor, evaporator and you should be good to go.
Have the shop evacuate the system, if it hasn't been done professionally or by the Corvette's free will.
-Steve
Old Feb 9, 2004 | 02:47 PM
Pauld's Avatar
Pauld
Default Re: How difficult is it to remove the A/C? (LT-1 Larry)
I guess it's bad but what happens when you are exposed to freon??? :confused:
Old Feb 9, 2004 | 03:58 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: How difficult is it to remove the A/C? (Pauld)
It melts your face, man. :eek: :D
Actually, my understanding is that it isn't particularly poisonous, and that the worst it will do unless you are sitting in a room full of it (or lying under a car in a garage) or you huff too much of it (yes, some folks use it as a recreational inhalant :rolleyes: ) is dizziness, an anesthetic effect, and eventually unconsciousness. The problem with the small room thing is that it's heavier than air and displaces it--so if you're lying under a car in a pool of the stuff, you could suffocate.
BTW, if you decide you want to sell that A/C stuff, lemme know. I'm trying to restore the A/C on my '69.
JB
To How difficult is it to remove the A/C?
