Pulling off the rear hub
Old Feb 10, 2004 | 07:11 PM
Ben's75's Avatar
Ben's75
Default Pulling off the rear hub
The parking brake lever has been damaged (or something) and is now rubbing against the rotor. Nice loud noise, eh! How hard is it to pull the hub off? Take off the caliper, pull off the half-shaft - then what? Pics would be most appreciated. One day job? Should I do my wheel bearings while I'm at it?
Ben
Old Feb 10, 2004 | 07:46 PM
motown 71's Avatar
motown 71
Default Re: Pulling off the rear hub (Ben's75)
You should be able to remove the parking brake lever without pulling much more than the caliper. Of course you'll have to release the tension on the cable. As for barings the rear are not like the front. This the rear bearings are huge job on the vette. Great info in the archives if ya do a search.
Good luck.
:steering:
Old Feb 10, 2004 | 11:20 PM
FeedVaal's Avatar
FeedVaal
If the hub has not been off before, you'll have to drill out 5 rivits which were done at the factory to facilitate assembly. This is a lot easier to do with the swing arm off the car. If you pull the wheel and see rivits, your looking at a weekends worth of work.
Old Feb 11, 2004 | 03:17 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Re: Pulling off the rear hub (FeedVaal)
You only need to pull of the rotor to get to all the e-brake stuff. Like they said, if you see rivets they need to be drilled out. Rotor *should* come off (spent 2 hours trying to pry off a rusted one), no need to disconnect halfshafts.
Old Feb 11, 2004 | 06:20 PM
Ben's75's Avatar
Ben's75
Default Re: Pulling off the rear hub (Buffalo Dude)
Cool, well, the rivets have already been drilled on mine. I trust it will be obvious what to remove to disable the e-brake.
Thanks for all the help guys - ya'll are the best. :cheers:
Old Feb 12, 2004 | 09:54 AM
Grinchia's Avatar
Grinchia
Just did this last week (drilled rivets/rotor removal, that it), and got a helpful tip here...the rotor will probably be rusted on, and prying could take FOREVER...so grab a rubber mallet and give the rotor a few sharp whacks, and it will pop loose in about 10 seconds.
-Roy
To Pulling off the rear hub
