Throttle Cable bracket for Demon carb?? Help
Old Feb 10, 2004 | 08:58 PM
Morgan6t9's Avatar
Morgan6t9
Default Throttle Cable bracket for Demon carb?? Help
Have a 69 and have installed a Demon carb. Old throttle cabel bracket is for a Rochester carb I think. Has anyone else found a off the shelf solution to this?
Old Feb 10, 2004 | 09:01 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Throttle Cable bracket for Demon carb?? Help (Morgan6t9)
Have you looked at the Lokar stuff. I had to install one of thier brackets and throttle cable to get mine to work.
Old Feb 11, 2004 | 08:42 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I bought a chrome bracket summit sells. It bolted right under the carb and had an adjustable cable attachment.
Old Feb 11, 2004 | 11:23 AM
67-L89's Avatar
67-L89
I have this CSI bracket form Sumitt. It was kind of expensive but it works and looks good.
[Modified by 67-L89, 2:08 PM 2/11/2004]
[Modified by 67-L89, 3:42 PM 2/11/2004]
Old Feb 11, 2004 | 06:44 PM
Morgan6t9's Avatar
Morgan6t9
Thanks. that set up looks awesome. Have any idea what the part number was. I looked and did not see any for Demons specifically.
Old Feb 11, 2004 | 09:12 PM
OkeeGuy's Avatar
OkeeGuy
i am interested in this too as i am buying a Demon next week...
will my stock cable not hook right up to the Demon?
if not...part numbers please???
Old Feb 12, 2004 | 02:19 AM
Solid LT1's Avatar
Solid LT1
Default Re: Throttle Cable bracket for Demon carb?? Help (SIGNGUY)
Get a bracket for a LT-1 Vette with a Holley. They work perfect!
Old Feb 12, 2004 | 02:46 PM
apple76's Avatar
apple76
Default Re: Throttle Cable bracket for Demon carb?? Help (Solid LT1)
A Demon carb was installed last year on my 76. The original bracket was used but it had to be modified quite a bit...
Old Feb 12, 2004 | 04:36 PM
67-L89's Avatar
67-L89
This is a CSI-630R (Red) bracket. I know it will work with 75 thru 81 Vette throttle cables with the square clip in holder. Check with Sumitt customer service for the earlier Vettes. Remember that the Demon carb is virtually the same in every way as the Holley 4150. If you use this bracket you will also need slightly longer carb mounting studs and get a good double return spring and stretch it so as not to put too much pressure on the carb throttle shaft.
Old Feb 12, 2004 | 09:39 PM
69vette66's Avatar
69vette66
Default Re: Throttle Cable bracket for Demon carb?? Help (67-L89)
http://lokar.com/images/large_lorez_...ble_hitech.jpg http://lokar.com/images/large_lorez_...cket_mount.jpg I am picking this up for mine on saturday. they say it fits like a glove.
:cheers: Larry
Old Feb 13, 2004 | 01:06 AM
71roadster's Avatar
71roadster
Default Re: Throttle Cable bracket for Demon carb?? Help (69vette66)
cant help with the throttle bracket question, but I have a speed demon 750 listed in the for sale section of the forum.
Chris
Old Feb 13, 2004 | 10:00 AM
no_radio's Avatar
no_radio
Default Re: Throttle Cable bracket for Demon carb?? Help (71roadster)
The Demon has rounded corners whereas the Holleys seem to have squared off corners. I bought a couple of simple brackets (Mr Gasket) but they would rotate around the stud, so I drilled a small hole and used a roll pin to pin the bracket to the carb base, no problem, and cheap.
Jeff
Old Feb 15, 2004 | 07:54 AM
blue427's Avatar
blue427
where did you get the LT-1 bracket?I tried,Paragon told me they were no longer availible.thanks :confused:
Old Feb 15, 2004 | 08:59 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
[QUOTE]I have this CSI bracket form Sumitt. It was kind of expensive but it works and looks good.
I have one of those for sale.....
http://forums.corvetteforum.com/zerothread?id=714616
Old Feb 15, 2004 | 09:02 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Throttle Cable bracket for Demon carb?? Help (blue427)
I don't think the Holley-LT-1 brackets are available any longer. :(
[Modified by Jughead, 9:09 AM 2/15/2004]
Old Feb 15, 2004 | 09:12 AM
dman535's Avatar
dman535
Default Re: Throttle Cable bracket for Demon carb?? Help (Jughead)
Just about anything made for a square bore holley can be made to work on a Demon. I have a 700r4 and used a Holley Pro-jection bracket. A little cut here , bend here and BAM ! you have a good working throttle cable bracket !
Old Feb 15, 2004 | 09:40 AM
OkeeGuy's Avatar
OkeeGuy
just ordered mine along with a SD 750 and other "accessories"
had it all sent to Lars :D
To Throttle Cable bracket for Demon carb?? Help
