68 side vents need help.
Old Feb 11, 2004 | 05:44 AM
vette-freak's Avatar
vette-freak
Default 68 side vents need help.
I am in the process of installing chrome side vents on the 68. It seems to be going well with the exception of the rear vents on both sides. They are impossible to get to. How do I do this without disassembling the fender? Any ideas?
Old Feb 11, 2004 | 06:56 AM
WESCH's Avatar
WESCH
Default Re: 68 side vents need help. (vette-freak)
Hi
What's the problem ?
Don't they fit the hole ? Or can you not reach the nut ?
I also have this on my 68 and I love them.
:seeya
Gunther
Old Feb 11, 2004 | 07:49 AM
sb69coupe's Avatar
sb69coupe
What are you trying to reach? All you do is drill the holes, insert the well nuts, put in the insert and tighten the screws. If you're not using the correct well nuts, that's the problem. All of the catalog vendors sell them.
Shannon
Old Feb 11, 2004 | 12:43 PM
markdtn's Avatar
markdtn
Default Re: 68 side vents need help. (sb69coupe)
:iagree: Has your rear vent been modified somehow?
Old Feb 11, 2004 | 01:52 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Is there a difference between the 68 and 69 side vents? The chrome inserts were only available as a factory option in 1969.
Old Feb 11, 2004 | 02:27 PM
BigBadRed's Avatar
BigBadRed
Default Re: 68 side vents need help. (6t9l4t6)
Where did you get the chomes. I want to replace mine with the chrome ones.
--marc
Old Feb 11, 2004 | 02:51 PM
sb69coupe's Avatar
sb69coupe
There is no difference between the 68 and 69 fenders. BigBadOrange, do you have the inserts now? If you have the inserts with the chrome edge but painted "vent' you should be able to strip off the paint to reveal the chrome on the entier insert.
Shannon
Old Feb 11, 2004 | 03:01 PM
Grinchia's Avatar
Grinchia
Default Re: 68 side vents need help. (BigBadOrange)
Yo, BBO...I have a set of chrome ones on the way for my '68, but only 7...if you replace yours, are you interested in selling the old ones? Assuming you can't strip away paint to reaveal chrome, I'd just get the one I need plated.
-Roy
Old Feb 11, 2004 | 04:14 PM
verskel's Avatar
verskel
Unfortunately there are 2 types of 1968 Corvette fenders. :eek:
There are those that are for 'heater' only cars & those that came with A/C.
For some reason, the 'heater' only cars have the last gill painted black and yes there is NO hole...... :crazy:
Sorry - but GM didn't put chrome in the gills from the factory & you'll have to modify your fender to make them work. The other 3 should fit fine.
Old Feb 11, 2004 | 04:27 PM
BigBadRed's Avatar
BigBadRed
Default Re: 68 side vents need help. (Grinchia)
grinchia, If I can find the 8th I would be VERY interested. Maybe a heads up trade? Because they are pot metal, the local chrome shop says that they will not guanetee the result. SO I figure I will sell them to someone who wants them as is.
Old Feb 11, 2004 | 04:47 PM
sb69coupe's Avatar
sb69coupe
Default Re: 68 side vents need help. (verskel)
There's no mention in the latest NCRS judging manual regarding these 2 different fender configurations. Every 68 and 69 that I've seen with original fenders has the 4th one blocked off and blacked out. The louver inserts will still fit in the 4th slot with no problem.
Old Feb 11, 2004 | 10:35 PM
verskel's Avatar
verskel
Okay, maybe my memory is failing me just a bit......there might be a recess....however, mine is an A/C car and is not blocked off at the 4th vent (or blacked out or whatever).
Also, 68 through 69 vettes vary since there were changes mid-year for both models. I'm not completely sure about the vents but based on experience it seems that ALL heater only cars have the 4th vent blocked / blacked out...etc.
There might be a recess but from memory I did not recall this.
early 68's with A/C & early 68's without A/C
late 68's with A/C & late 68's without A/C
early 69's with A/C & early 68's without A/C
late 69's with A/C & late 69's without A/C
Make up 8 assembly types without even separating the details between small block / big block cars.
Even NCRS is not the all knowing source for information.
Heck, GM seems to have lost track (although it's burried somewhere in paperwork).
:chevy
Old Feb 11, 2004 | 11:30 PM
Corey_68's Avatar
Corey_68
:iagree:
My '68 had original A/C and the last vent is blocked off. My chrome vents fit w/ no problems. :cheers:
Old Feb 12, 2004 | 11:57 AM
LemansBlue68's Avatar
LemansBlue68
Default Re: 68 side vents need help. (Corey 68)
The 4th vent actually covers the plenum that directs air from the base of the windshield to the floor vents in the kick panels. Without the block off, the air intended for cabin ventilation would vent out the fender and the kick panel vents would be useless. Removing the block off would not improve airflow through the engine compartment and would ruin the cabin ventilation. Therefore, there is no good reason why it would not be blocked off. Sounds like Bubba's been at work on some of these cars.
Old Feb 12, 2004 | 12:48 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: 68 side vents need help. (LemansBlue68)
My late '69 AC car has the 4th vent blocked off...
And the vents are just attached with screws.
Old Feb 12, 2004 | 03:31 PM
R1234's Avatar
R1234
Default Re: 68 side vents need help. (427V8)
My early 68 with A/C has the 4th vent blocked off. Also the driverside interior vent plenum is blocked off from the factory allowing no manual vent.
Old Feb 12, 2004 | 03:37 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: 68 side vents need help. (68rdstr)
:withstupid:
Old Feb 12, 2004 | 05:49 PM
verskel's Avatar
verskel
Default Re: 68 side vents need help. (Cali,68,L-79)
:withstupid:
:confused: .....now I'm getting suspicious :skep: ....tonight I'll check out my fenders and see if ugly Bubba has done it to me again. :rant:
Old Feb 12, 2004 | 08:03 PM
shark food's Avatar
shark food
ALL 68 and 69 fenders are the same whether they have a/c or not! The fourth gill is allways blacked out and blocked off from the factory. The only time it wasn't blacked out was on a tuxedo black car of course. The louver option was a 69 only option and wasn't even offered durring early production, however they will fit just the same on a 68. Just make sure you drill the holes correctly good luck!
To 68 side vents need help.
