timing chain replacement ?
Old Feb 11, 2004 | 03:57 PM
yosshimura's Avatar
yosshimura
Default timing chain replacement ?
:( My freinds 78's timing chain went capute yesterday. As soon as we heard the noise under the engine (driving) we shut engine off not knowing what had occurred. My diagnosis is timing chain unfortunately.... no start, just cranks, plus the noise factor at the time :rolleyes:
Anyway, I am not sure I want to mess with it , last time I did a water pump job (pretty much the same when it comes to dissasembly all the stuff up front )... it took like 6-8 hrs at home :( ...
How much does it take a shop to do? Trying to figure out how many hours they would charge? 3 hrs sounds right with the right tools , and a professional mech... I am guessing.
Could any other damage have occured in there? Or once the chain goes all stops so no bent valves etc? or the opposite, once engine stops valves get bent and all hell falls apart in there? :bs :cry
thanks
Old Feb 11, 2004 | 04:16 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: timing chain replacement ? (yosshimura)
I'm not sure what a shop would charge but there is a good chance some valves were bent. It would be smart to pull the heads and see if there are marks in the top of the pistons. A borescope or leakdown test may tell you something without removing the heads but they are not as definitive as a good visual inspection. This is a good opportunity to upgrade the cam.
Old Feb 11, 2004 | 05:02 PM
comp's Avatar
comp
Default Re: timing chain replacement ? (burners)
if the water pump was tough get some help, this is much more , don't get in
a hurrry or cut corners... check everything :thumbs:
Old Feb 11, 2004 | 05:03 PM
Fevre's Avatar
Fevre
Had a shop replaced one in a 79 olds, week after I got it back it spun a bearing (assuming from the LOUD squeeling from inside the eng), shop says must have got some nylon from the teeth in the oil pump, would not warranty it so i was out $400. :mad Moral: replace your oil pump if the gear had nylon teeth.
Old Feb 11, 2004 | 05:05 PM
marshrat99's Avatar
marshrat99
:iagree: with Burners. Pull the heads and inspect for damage. I also agree that now would be the perfect time to upgrade to another cam. Good luck. :cheers:
Old Feb 11, 2004 | 05:24 PM
Vette'78's Avatar
Vette'78
Default Re: timing chain replacement ? (marshrat99)
Is it really that difficult to replace your timing chain?
Old Feb 11, 2004 | 06:26 PM
fauxrs's Avatar
fauxrs
Default Re: timing chain replacement ? (Vette'78)
No but it is time consuming, should be done with proper tools and can take some time. If a water pump took as long as it took him, expect to take a whole weekend.
Make sure to rent/purchase a balancer puller and installer. There will be nylon in the pan if the chain failed as described. and yes it would be wise to check for bent valves. also a gear puller to get the bottom crank gear off.
A timing chain is not difficult to do, but you will want to take your time. I did mine about 5 years ago, it took about 6 hours with the right tools, I did not check the pan because the chain did not fail and the teeth were still there, the chain had merely stretched.
good luck
Old Feb 11, 2004 | 08:25 PM
joeveto's Avatar
joeveto
Cruise-In V Veteran
St. Jude Contributor
The job is time consuming, the first time around. After that, it's cake. You know, the whole "learning curve thing."
Just the same, if the friend does not need the car for awhile, I say "go for it." It'll surely be a great learning experience and will be a lot less expensive.
Old Feb 11, 2004 | 10:11 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
If a water pump is a problem for you let the timing set go to a local pro Yosi. :yesnod: And if greesy mechanical work is not your bag it would be benificial for you to seek out good local mechanics. Now the Chevy dealer would be the place to get a baseline estimate - to ensure another shop doesn't try to overbill you. Take a look at the nearest Corvette specialty shop as you will have more corvette work with time and use (and abuse).
Sometimes it take a few tries to find a trusy shop but we all need one sooner or later. :D
Happy hunting. :chevy
Old Feb 11, 2004 | 11:01 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Re: timing chain replacement ? (cardo0)
In some of my other cars over the years they had timing belts that I replaced at 60K-70K miles. These cars have a timing chain with nylon teeth? Is there a mileage interval they should be changed at? Or generally good for 150K miles? or 30years? forever?
Old Feb 12, 2004 | 03:25 AM
Vette'78's Avatar
Vette'78
Default Re: timing chain replacement ? (fauxrs)
good luck
I have the puller but not the installer.......wheres a good place to get one? I'm in this to learn so I am going to do everything I can (probably a couple that I will regret)[
[Modified by Vette'78, 3:26 AM 2/12/2004]
Old Feb 12, 2004 | 08:29 AM
Ganey's Avatar
Ganey
Default Re: timing chain replacement ? (Dk Met Grn 80 L82)
In some of my other cars over the years they had timing belts that I replaced at 60K-70K miles. These cars have a timing chain with nylon teeth? Is there a mileage interval they should be changed at? ...
Replace as soon as you buy the car. It is however a reliable system, expect chain to have slack by 50k. Maybe some could get over 100k if they don't drive hard, if neglected too long the nylon teeth will break off.
Roller timing set, cam & intake all at once rec. as soon as you buy the car.
Old Feb 12, 2004 | 09:00 PM
Dk Met Grn 80 L82
Default Re: timing chain replacement ? (Ganey)
Mine has 107,000 miles so I guess it is time. Sounds like something I will have to add to the list for this summer. Should I change the water pump at the same time since I will have all of the front stuff off already?
Old Feb 12, 2004 | 11:23 PM
Ric's80_4sp's Avatar
Ric's80_4sp
This web site helped with my cam/chain replacement project. http://www.bokonon.net/corvette/cam1.html
[Modified by Ric's80_4sp, 10:29 PM 2/12/2004]
Old Feb 15, 2004 | 10:54 PM
Dk Met Grn 80 L82
Default Re: timing chain replacement ? (Ric's80_4sp)
Good link, thanks.
To timing chain replacement ?
