Brakes
Old Feb 11, 2004 | 06:50 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Brakes
How can you tell if the brake booster has gone out or the master cylinder? My brakes feel like they are gone. I SLAM the pedal down and it takes a while to stop. The brakes are WAY too mooshy. Any tips are greatly appreciated.
Old Feb 12, 2004 | 10:15 AM
comp's Avatar
comp
Default Re: Brakes (ElectronBlueC3)
listen for a vac. leak, does the idle RPM go up when your foot is on the brake
pedal or is it idling a little fast al the time? clamp off vac. line to booster test
for a change
Old Feb 12, 2004 | 11:37 AM
L824spd's Avatar
L824spd
When the power brake booster goes it will be like driving with manual brakes. The pedal will stay high but it takes a WHOLE lot of pressure. If your pedal is mushy or goes to the floor you most likely have a leaking master cylinder or caliper. Or you have air in the system. I feel your pain. Trying to mine safely streetable after 3 years (maybe more?) of sitting in the basement.
To Brakes
