tach hookup
Old Feb 12, 2004 | 12:34 PM
madvette74's Avatar
madvette74
Default tach hookup
i have a sun tach with 4 wiresred blue green black on my hei i have red power wire, yellow,brown ,and black, anyone know how to hook this up?
Old Feb 12, 2004 | 04:00 PM
verskel's Avatar
verskel
Default Re: tach hookup (madvette74)
The red wire from the tach goes to the +pos. batt. terminal.
The black wire from the tach goes to the -neg. batt. terminal.
The blue wire (should be white) goes to the dash lights for lighting the tach.
The GREEN wire is the 'tach' wire & goes to the +pos. side of the COIL.
Hope that helps. There should only be 1 wire going to your coil.
**Please verify this information before Installation. ;)
Wire colors can vary between aftermarket tachs.....
Old Feb 12, 2004 | 04:09 PM
SLine78's Avatar
SLine78
On a GM HEI Distributor, there are two external connections on the cap. One is for power and the other is for the Tach. Hook the green wire to the tach terminal on the distributor cap.
Mike
[Modified by SLine78, 1:11 PM 2/12/2004]
Old Feb 12, 2004 | 07:29 PM
madvette74's Avatar
madvette74
Default Re: tach hookup (verskel)
on the HEI i have i red power, and three wires colors yellow, brown and black, so the green tach wire goe's to wich HEI wire, yellow or brown (cant be black)
thanks, this is for my sons 66 GTO
Old Feb 13, 2004 | 01:45 AM
stickboy's Avatar
stickboy
On your HEI cap there is a terminal marked 'tach' it will be directly beside the wire marked 'batt' If I am reading your post correct you are looking at the 3 wires that go from the base to the cap. These are not for the tach hookup and connect to the cap behind the tach/batt terminals
Old Feb 13, 2004 | 09:27 AM
madvette74's Avatar
madvette74
Default Re: tach hookup (stickboy)
oh, i see what our talking about. thanks
To tach hookup
