Anyone read this artical in the April issue of Chevy High Performance? They are bragging about the street worthy performance of some 1-1/2" dia intermediate-length headers on a 440 hp 383. I bet you guys with the 1-7/8" dia looooong tubes of the Hooker side pipe headers are leaving a lot of low end torque on the table....but maybe you still still have too much!
Saw some dyno tests with the GM HT383 after head and cam swaps and they found that it made more power with the 1 5/8" primaries than with a 1 3/4" primaries.
:eek:
I have no stinkin' problems with lack of "low end"...... :D
Of course a 'stroker' small block ain't a Big Block neither ! :lolg:
Besides the God aweful price of sidemount headers,this is the main reason I went with an under car header system. I've seen countless dyno tests indicating the benifits of small tube primaries on street driven engines.Of course at the topend the big tubes will always produce more hp at the peak rpm,but what about the other 95% of the torque curve?
On my website there's a buildup article that shows 40 lbs tq. midrange gain with 1 5/8" tubes with only 12 hp topend loss when the same engine ran 1 3/4" tubes.
I've got a set of 1 5/8" Hedman long tube headers (with A.I.R. tubes) on my car now that I'd be more than happy to swap straight up for a set of 1 3/4" long-tube primary headers. Just so long as they're in comparable shape--i.e. cosmetic tweaking only.
In regards to the testing of the HT383 with TFS alum heads and a big o roller cam:
Almost as interesting is the fact that even with the larger cylinder heads, this 383 still doesn't like larger headers. Despite these lofty power levels, this engine is breathing through a stock Performer RPM Air Gap intake and a set of production 1-5/8-inch Hedman street headers and a pair of Borla mufflers. Taylor tried a set of 1-3/4-inch tubes and came away with less power. This is flat-out amazing power from an otherwise off-the-shelf 383ci crate engine. We have never pulled a piston out of its bore or even yanked the oil pan. Taylor bolted in a big Comp Cams hydraulic-roller cam, a set of 215cc TFS aluminum heads, and a dual-plane intake. These are Rat motor numbers in a lightweight package. Idle vacuum isn't all that stout at around 8.5 inches of vacuum at 900 rpm, but the amazing torque is more than enough to live up to its namesake.
I don't see the intermediate length Flowtech headers on Holley's site; must be new. From the picture in the mag, they look like they would be great for connecting to side exhausts; not as short and compromising as block huggers and not as long as a full length header which require a u-bend.
