Stock 4-speed shifter assembly slop
I finally crawled underneath today and removed the shifter unit to see what a good cleaning and greasing might accomplish...UGLY! :rolleyes:
I'm going to go clean 'er up, but one thing I noticed is that the shaft of the shifter, where it inserts into the cast/chromed piece that actually pivots, is loose. There is about 1mm of vertical play, and quite a bit of lateral slop. It appears as though the two pieces are not meant to be separated. Can I snug this up somehow? I figured either get some JB Weld in there (bubba :rolleyes: ), or else have a buddy spot weld a few points around the edge to prevent any further movement (it won't be seen beneath the upper shift boot anyway). Has anyone tried this? Any better ideas? Anyone who has a decent Hurst setup for a '68 4-speed that they don't need anymore? :D
P.S. I ordered the polished alloy Torq Thrust IIs in 16x8 yesterday :party:
...just hope my wife doesn't see how much :D
-Roy
[Modified by Grinchia, 1:20 PM 2/14/2004]
