I ordered a balancer form corvette central. it came in quickely.
I was anxious to install and did it right away. Now i notice that it is
slightely larger diamater than the original. Everything else has clearance but
I need to know if I can run this one or should I return for smaller balancer.
:banghead: :banghead:
it is a 350 motor
I don't think the diameter matters as long as it is neutrally balanced or offset balanced like in the case of the 454. As long as the balance is right for your combination it will be all right.
