How would you fix this??
Old Feb 15, 2004 | 12:46 AM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default How would you fix this??
I removed the fuel tank, found wood paneling. Is this a normal hole for a replacement clip, and a build sheet?
Old Feb 15, 2004 | 01:15 AM
wacked's Avatar
wacked
Default Re: How would you fix this?? (wackedvette)
More pics.
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
Old Feb 15, 2004 | 01:18 AM
wacked's Avatar
wacked
The cut's in the frame, realy bother me. What would you do? My options are to have a Hobart Welder fix it, or scrap it? :mad
Old Feb 15, 2004 | 04:59 AM
sammyb's Avatar
sammyb
Wow, I see you have the rare "cat power" regular production option! :crazy:
Old Feb 15, 2004 | 05:27 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: How would you fix this?? (sammyb)
omg, who owned that car before you? a carpenter?? Geez..that's a lot of work.
Old Feb 15, 2004 | 06:32 AM
Disco_Mike's Avatar
Disco_Mike
:eek: :eek: and more :eek:
Old Feb 15, 2004 | 06:43 AM
RHD '68 L89's Avatar
RHD '68 L89
I cannot see the cuts in the frame from the pics. If they are just 1/8in cuts weld them up with an Arc or Mig welder. once you are past the diff mounts there is not much strain on the chassis.
What is a Hobart welder?
:cheers:
Old Feb 15, 2004 | 07:18 AM
stingraymaniac's Avatar
stingraymaniac
Default Re: How would you fix this?? (RHD '68 L89)
ouch!!!
lots of work there!
i would just weld it up if its only those rectangular holes i se in the pics
keep up the good work!
Old Feb 15, 2004 | 09:08 AM
brs6482's Avatar
brs6482
Hobart is just a brand of welder...
Old Feb 15, 2004 | 09:49 AM
ettev's Avatar
ettev
Send these pictures to the guys at Contemporary Corvettes in Bristol, Pennsylvania. They'll send you all the correct fiberglass to patch that hole the right way.
Old Feb 15, 2004 | 09:53 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
:eek: Wow, that certainly is quite a project. :eek: You could probably get a rear clip and find all the panels you need to make the thing solid again. Even a mildly wrecked rear clip would probably work from what I can see. :cheers:
Old Feb 15, 2004 | 11:12 AM
MGB's Avatar
MGB
St. Jude Donor '14
What year vette. is this? Where is the build sheet found on the tank? side, top etc. Can you see it through the gas filler area if the rubber surround is removed. Good luck!!!
Old Feb 15, 2004 | 11:29 AM
78 Vette's Avatar
78 Vette
Default Re: How would you fix this?? (MGB)
:eek: :eek: Wow the last guy was a real butcher. I think I would do as suggested earlier in this tread get the correct fiber glass and mold it in. Good thing your smart enough to do all your own work I couldn't imagine paying to do all this stuff.
Old Feb 15, 2004 | 03:32 PM
reidry's Avatar
reidry
Default Re: How would you fix this?? (78 Vette)
Yikes! :eek:
I think you're gonna need more than a tail light panel!
I've got two gutted bodies on hand, a '69 and a '70. Let me know if I can send you any pictures to help in the reconstruction.
Edited to add ... I'm not even sure what angle picture #4 was taken from ... what is that showing??
Ryan
[Modified by reidry, 8:34 PM 2/15/2004]
Old Feb 15, 2004 | 04:29 PM
wacked's Avatar
wacked
Default Re: How would you fix this?? (reidry)
Thats just my tank on the floor, could you get me some pics?
Old Feb 15, 2004 | 10:16 PM
reidry's Avatar
reidry
Hmm ... put learning to count on my list of things to do.
I meant picture 5.
I'll shoot some tomorrow evening for you. I have a 70 body in the shop that's in nice primer should be great for some tank area shots.
Ryan
To How would you fix this??
