Manifold Vacum Fitting
Old Feb 15, 2004 | 10:26 AM
mlc68vette's Avatar
mlc68vette
Default Manifold Vacum Fitting
I am changing the intake manifold on a 327 small block to an Edlebrock EPS. The vacum fitting is partially blocked by the carb (Road Demon) when installed. There is only about 1/2" clearance uncer the fuel bowl and the maniflold. Any ideas on what fitting I can use? The stock fitting is way too tall. :banghead:
Old Feb 15, 2004 | 10:29 AM
Last Place's Avatar
Last Place
Default Re: Manifold Vacum Fitting (mlc68vette)
Edelbrock sells a low profile, 90degree fitting just for this. I'll see if I can find it and post it :cheers:
Old Feb 15, 2004 | 10:31 AM
mlc68vette's Avatar
mlc68vette
Default Re: Manifold Vacum Fitting (Sling Blade)
That would be greatly appreciated. :)
Old Feb 15, 2004 | 10:32 AM
Last Place's Avatar
Last Place
http://edelbrock.com/automotive/install2.html
Part number 8096. There is a picture of it at the bottom of the page. Second row, far right.
Hope this helps :seeya
[Modified by Sling Blade, 10:33 AM 2/15/2004]
Old Feb 15, 2004 | 10:37 AM
mlc68vette's Avatar
mlc68vette
Got it! Thanks for your help.
I have another quetion if you don't mind. I posted this a few days ago and got no response.
I want to install an aftermarket fuel filter. What do I do with the vent return connection?
Old Feb 15, 2004 | 10:40 AM
Last Place's Avatar
Last Place
The filter has a vent return:confused:
I'm not really sure; hopefully someone else will step in and answer. :cheers:
Old Feb 15, 2004 | 10:50 AM
mlc68vette's Avatar
mlc68vette
Yes. The filter has a vent fitting that with a line that runs back to the tank.
Thanks anyway. I already ordered the fitting! :lolg:
Old Feb 15, 2004 | 11:06 AM
69vette66's Avatar
69vette66
there is another company called mo-speed that makes a better one. This came from the http://www.c3sharktank.com/ check it out http://www.c3sharktank.com/tech2/vacfitting/index.html I saw it just bit ago.
:cheers: Larry
To Manifold Vacum Fitting
