power steering cylinder
Old Feb 15, 2004 | 01:48 PM
71stockray's Avatar
71stockray
Default power steering cylinder
Help! I am in the process of rebuilding my power steering cyl. and valve I got thr cyl. off the car removed the ball stud, but can not get the piston out of the cyl. removed the snap-ring and washer I am sore this comes out the top. I really do not want to put this back in without changing the bottom seal. I have it sitting on the bench right now. Please some advise! Thanks
Old Feb 15, 2004 | 06:45 PM
Jim Shea's Avatar
Jim Shea
Default Re: power steering cylinder (71stockray)
You cannot get at the piston inside the cylinder. The cylinder end caps are welded in place. GM must think that a little bit of internal leakage (past the plastic seal on the piston) would not be a problem with the cylinder. What's a little bit of internal leakage among friends!
