ugh...another electrical problem
Old Feb 15, 2004 | 04:08 PM
kwg's Avatar
kwg
Cruising
Default ugh...another electrical problem
Hi all,
The instrument lights in my '79 went out a few days ago. I searched the topic on this board and I found out that the gauge lights are tied to the tail lamp fuse. I checked that fuse and, sure enough, it was blown. I replaced it and the lights came back on, but then when I started the car, the fuse blew again. I replaced it again, and it immediately blew again, and it also took out the radio. Any suggestions?
Old Feb 15, 2004 | 07:40 PM
kwg's Avatar
kwg
Cruising
Default Re: ugh...another electrical problem (kwg)
i know somebody has a guess. i'm desperate, my back is killing me from contorting around in the footwell!
Old Feb 15, 2004 | 09:14 PM
Fleetwood's Avatar
Fleetwood
Finding shorts is a case of elimination,in your case it could be a short on the printed circuit on the back of the gauge panel,or one of the several globe holders mounted on the back of the gauge cluster.You will need to remove the gauge panels to establish that,& check the wiring.
Do you have a decent circuit diagram,if not I would suggest you get one before attempting any electrical repairs.
Neil.
Old Feb 15, 2004 | 09:20 PM
78 Vette's Avatar
78 Vette
Default Re: ugh...another electrical problem (Fleetwood)
Hey KWG where on Long Island are you from? That is where I am to. :cool:
Old Feb 15, 2004 | 10:33 PM
kwg's Avatar
kwg
Cruising
Default Re: ugh...another electrical problem (78 Vette)
I'm in Jericho. Where are you?
Old Feb 15, 2004 | 11:13 PM
goinbroke's Avatar
goinbroke
Here is a diagram that may help. http://www.corvetteforum.net/c3/tune.../index23.shtml
Old Feb 16, 2004 | 12:32 AM
duntovlives's Avatar
duntovlives
some advice as to finding your short, hopefully it might save you some time. before you dive into the more difficult aspects, eliminate the easy to reach ones first. example, unplug the rear harness to the tail lights and see if the fuse still blows. if it doesnt, then you have narrowed the search. do this with each leg until you find the source.
also, keep an eye out for "non factory" wiring. it seems more times than not, electrical probs are caused due to "human error".
good luck
:thumbs:
Old Feb 16, 2004 | 11:13 AM
78 Vette's Avatar
78 Vette
Long Beach see you at the shows :thumbs:
Old Feb 16, 2004 | 11:22 AM
75stinger's Avatar
75stinger
When I had this problem it was the headlight switch
To ugh...another electrical problem
