Help! Gas Tank Removal
Old Feb 15, 2004 | 06:37 PM
c3-4me's Avatar
c3-4me
Default Help! Gas Tank Removal
Nearing the completion of my rear end rebuild. Came out to the garage to find a couple of those dreaded 'spots' on the card board. But this time it was under the gas tank! I wiped the tank to see what was going on and now its a steady stream! :cuss :cuss
I can see how to drop the tank, but how do you disconnect the lines before dropping it?? Does anybody have pics or a exploded drawing of of the lines that may help??
Also, does anyone have a good recommendation for a reconditioning service since its impossible to buy a new one for a 1980??
Old Feb 15, 2004 | 06:58 PM
GDaina's Avatar
GDaina
Default Re: Help! Gas Tank Removal (c3-4me)
you should have a small section of rubber line going from the sending unit to the fuel line. If you have a return line, then two rubber lines should be visible. The steel lines run on top of the right rear frame rail. Pliers will disconnect the clamps.
Old Feb 15, 2004 | 07:09 PM
c3-4me's Avatar
c3-4me
Default Re: Help! Gas Tank Removal (GDaina)
When I look at the passenger side of the tank, I see 2 steel lines that go towards the top. I don't see any rubber lines. Should I be reaching around on top to feel my way around??
Old Feb 15, 2004 | 07:23 PM
GDaina's Avatar
GDaina
The rubber lines are there....only way to connect the steel lines to the tank's sending unit.
Old Feb 16, 2004 | 11:30 AM
Richard Cooper's Avatar
Richard Cooper
When I removed the tank from my 81 I removed the straps and lowered the tank using a piece of plywood and hydraulic jack. I lowered the tank just enough where I could reach in where I had removed the filler cap and disconnect the lines. :thumbs:
Old Feb 16, 2004 | 12:36 PM
stingraymax's Avatar
stingraymax
Default Re: Help! Gas Tank Removal (Richard Cooper)
You can also disconnct the two right hand lines thru the top . Just remove the fillerneck rubber and you should see the sending unit and the connected lines.
Watch out on my 75 there is also a line on the left hand side.
Check here : http://www.vettefinders.com/index.cf...101Story&ID=10
[Modified by stingraymax, 5:40 PM 2/16/2004]
Old Feb 16, 2004 | 04:34 PM
c3-4me's Avatar
c3-4me
Thanks guys! :thumbs:
Old Feb 16, 2004 | 04:43 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Mine slid right out, due to no tail lamp panel on it at the time.
The ruber lines are short.
Old Feb 16, 2004 | 04:53 PM
The Money Pit's Avatar
The Money Pit
I disconnected everything from the top after removing the filler cap door and trim.I got a replacement from Zip about four years ago.These tanks had internal bladders and I've never heard anyone repairing this type of tank.
To Help! Gas Tank Removal
