Clutch Noise
Old Feb 16, 2004 | 10:08 AM
mstanton's Avatar
mstanton
Default Clutch Noise
My 71 has started to make a fairly loud noise when the clutch is engaged. It only happens when starting from a stand still and doesn't happen everytime. The noise is a whining, not a klunk and does not occur when fully engaged. Any help is appreciated. Thanks
Old Feb 16, 2004 | 10:31 AM
djgrelli's Avatar
djgrelli
Default Re: Clutch Noise (mstanton)
Sounds like the old throw out bearing needs replacement.
Old Feb 16, 2004 | 03:11 PM
marshrat99's Avatar
marshrat99
Default Re: Clutch Noise (djgrelli)
:iagree: About how many miles do you think you've got on your clutch and throwout?
Old Feb 16, 2004 | 05:26 PM
mstanton's Avatar
mstanton
Default Re: Clutch Noise (marshrat99)
Odometer shows 74K which I believe to be correct. Is this a fix right away or something that can wait?
Old Feb 16, 2004 | 10:51 PM
marshrat99's Avatar
marshrat99
Personally, I'd limit my driving to very short trips until I got it fixed. When the throwout goes, you'll be stranded. Also, I've seen them fly apart and damage the clutch and pressure plates. :cheers:
Old Feb 16, 2004 | 10:56 PM
mstanton's Avatar
mstanton
Thanks. :)
To Clutch Noise
