1980 Alternator #'s Question.
Old Feb 16, 2004 | 10:47 AM
Vettesic's Avatar
Vettesic
Default 1980 Alternator #'s Question.
The alternator bearing on my 80 is starting to make a grinding noise. I discovered it's not the correct unit according to the Black Book. The alternator that's in there now has no numbers at all. Where are the numbers supposed to be? Also how or where can I find a matching alternator that belongs in my year vette? The Black Book gives me 5 units to go by. Does this mean any one will be correct? Here are the #'s.....1101041, 1101075, 1101085, 1101088, 1103122. Any help would help. Thanks, Paul.
Old Feb 16, 2004 | 11:02 AM
stpman's Avatar
stpman
Default Re: 1980 Alternator #'s Question. (Vettesic)
The numbers are stamped in the case (front half i think).
the number and amperage are stamped together.
Steve :steering:
Old Feb 16, 2004 | 05:56 PM
mapman's Avatar
mapman
The NCRS Technical Manual for 1980-1982 lists the following alternators:
1102484, 42 Amps, Base model application
1102474, 61 Amps, C60 Application (Manual AC Control)
1103122, 63 Amps, C60 Application (Manual AC Control)
1101041, 70 Amps, Application 1st Production
1101075, 70 Amps, Application 2nd Production
Some vendors sell specific part number alternators but the ones I have seen are all for earlier Corvettes (1976 latest). It wouldn't hurt to ask (Zip, etc)
Old Feb 16, 2004 | 11:01 PM
Vettesic's Avatar
Vettesic
Default Re: 1980 Alternator #'s Question. (mapman)
The car does have AC.....What is manual control? How do I know what alt. is the correct for an L-82?
Old Feb 17, 2004 | 12:37 AM
mapman's Avatar
mapman
...... The car does have AC.....What is manual control? How do I know what alt. is the correct for an L-82?
All 1980s had AC standard. Looking at the Corvette Black Book, "C60" is listed as the code for optional Air Conditioning from 1963-1979. Why the NCRS pub shows the code :confused: . As your car is an L82 it most likely would have had the more powerful alternator for the aux radiator fan. My 1980 L48 had the 63 Amp alternator.
I replaced the old alternator with a 66 amp ACDelco alternator. My car, however, is intended to be just a driver. I don't want to spend the extra $$ necessary to chase down the parts necessary to bring it to NCRS standards. I use ACD and GM replacement parts for most everything, but they are the current "functional" parts, not the "original" parts.
Old Feb 17, 2004 | 07:20 AM
Vettesic's Avatar
Vettesic
mapman....Thanks. Would a part # help, if I had a source to obtain one?
Old Feb 17, 2004 | 07:36 AM
mapman's Avatar
mapman
Depending on your VIN #, I would give the vendor the PN of the 70 Amp alternator. (Low VIN # = 1st Production, High VIN # = 2nd Production)
As to vendors, you might try posting the question over on the NCRS site.
Old Feb 17, 2004 | 09:55 AM
Vettesic's Avatar
Vettesic
Thanks for the direction.
Old Feb 17, 2004 | 09:57 AM
Jim Shea's Avatar
Jim Shea
You might also try Paragon Reproductions. They specialize in scouting out old OEM parts.
Old Feb 17, 2004 | 10:02 AM
Vettesic's Avatar
Vettesic
Default Re: 1980 Alternator #'s Question. (Jim Shea)
k.....Would you happen to have their 800 # ?
To 1980 Alternator #'s Question.
