front rotor rivet removal help
Old Feb 16, 2004 | 05:46 PM
kenko74's Avatar
kenko74
Default front rotor rivet removal help
What's the best way to remove the rotor rivets? I took increasingly larger diameter drills and drilled out the center of the flat end (outer) until the rivet heads popped off, then tried punching out the rivet with a 1/4 inch punch--but no luck yet. I drilled completely through the center of the rivet with a 3/16 inch drill bit, then tried a 1/4 inch punch, still no luck.
I don't want to use too big of a bit and overbore the holes. Can anyone tell me the diameter of the rotor/hub rivet holes?
Lastly, anyone ever replace the rivets, or just leave them out and let the lug nuts hold everything together?
Thanks,
Old Feb 16, 2004 | 05:59 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: front rotor rivet removal help (kenko74)
If I remember correctly, I used a 5/16 bit as the final drill thru. It wasn't immediately apparent to me but there was still a thin sliver of metal rivet holding the &%$#( thing together. I then ran a punch along the interior wall of the hole.
I didn't replace the rivets.
Old Feb 16, 2004 | 06:02 PM
StingrayDK's Avatar
StingrayDK
Hi there,
I facing the same problem in a short while, like to hear your experience once it done.
From what I understand you dont have to worry about replacing the rivets in the rotor, they where only installed to speed up the production line at gm.
Good luck.
Old Feb 16, 2004 | 06:10 PM
Grinchia's Avatar
Grinchia
I just did mine about 1 week ago. I drilled to 1/4" size, which was enough. It's hard work drilling ALL THE WAY THROUGH, and I discovered belatedly that you don't have to. Once there's a 1/4 inch hole at least 1/4' deep. take a chisel and use it to cut off the head of the rivet. The remainder can then easily be pushed out the back with a punch.
There is no need to replace them. You may find once the rivets are out that the rotor still seems immovable...30+ years of rust will do that ;) . Rather than trying to pry that sucker off, give it a couple of sharp whacks with a rubber mallet, and it will pop free and slide right off.
I was able to get away with having the fronts turned/trued, but the backs didn't have enough meat left on them to legally do that, so I had to replace them. Apparently they only allowed about .017 for wear on these rotors before replacement!
The local parts shop wanted $84.00 EACH to order in rotors for me...VBP has them for about $45 each plus shipping. I ordered mine from fastcorvette.com for $53.00 each with free shipping, super guy to work with.
You can find cheap rotors for around $30.00 per SET on E-bay (plus shipping), I don't know about the quality though.
Have fun!
-Roy
To front rotor rivet removal help
