Rear Defrost
Old Feb 16, 2004 | 07:59 PM
JDRez42's Avatar
JDRez42
Default Rear Defrost
The rear defrost in my 80 isn't working. When i hit the switch i hear a clicking niose come from the back and the little green light doesn't come on. Does anyone know where my problem is.
Old Feb 16, 2004 | 09:31 PM
YZ450FRACER165's Avatar
YZ450FRACER165
Default Re: Rear Defrost (JDRez42)
Check your fuse panel for the 20 amp fuse or you have a bad relay, had the same problem on my 80, turned out to be the fuse. Could also be a corroded wire or circuit. You can pick up a new circuit at Corvette Central and those types of places.
