Dang Thermostat!!!!
Old Feb 16, 2004 | 09:40 PM
YZ450FRACER165's Avatar
YZ450FRACER165
Default Dang Thermostat!!!!
My thermostat hasn't been working lately, well actually since I bought the car. I don't know what is wrong. I need some help, is there a bad contact, where is the contact, wire and temperature sender, and how do I test if the gauge is bad. One thing, I dont' have a continuity tester, so just anyone with experience on dumb luck with this, please help me out!! 1980 L-82
Old Feb 17, 2004 | 11:47 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Dang Thermostat!!!! (YZ450FRACER165)
To me a thermostat is something I put in the end of the upper rad hose to help the motor warm up quicker on cold days. It doesn't have a continuity test, any electronics of any kind.
'The sending unit in the head works with the gauge to read temperature.
Old Feb 17, 2004 | 12:07 PM
Pete76Shark's Avatar
Pete76Shark
Default Re: Dang Thermostat!!!! (norvalwilhelm)
:withstupid:
One suggestion, if you need to replace the thermostat ONLY use a CHEVY replacement. DO NOT buy the replacement theromstat from a parts vendor like NAPA or Autozone. I found that in this case the thermostat lasts longer if you get it from Chevy parts counter.
Old Feb 17, 2004 | 12:21 PM
verskel's Avatar
verskel
My first thought was to "ditch" the T-stat but then I saw where you live. :eek:
To test your current thermostat - put it in a pot of boiling water and see if the darn thing opens up......it's all mechanical so there's no contact to worry about.
As for your temp. sensor....it's either in the T-stat housing or in the water jacket of the cylinder head. Make sure your thermostat is working then post again for tips on checking your sensor / sending unit. ;)
Old Feb 17, 2004 | 12:24 PM
Ganey's Avatar
Ganey
Default Re: Dang Thermostat!!!! (Pete76Shark)
For temp. gauge- Ground the temp. sender wire momentarily, gauge should go to full scale if gauge & wiring are good. If so, replace sender.
Old Feb 17, 2004 | 04:45 PM
YZ450FRACER165
Default Re: Dang Thermostat!!!! (Ganey)
Sorry bout that. I meant that the temperature gauge isn't working. Any suggestions on that matter, cuz I hate when things don't work.
To Dang Thermostat!!!!
