Clock installation question
Old Feb 17, 2004 | 04:43 PM
iveka's Avatar
iveka
Default Clock installation question
I just got a new clock for my 76 Corvette becuse the old one hadn't worked since I bougt the car. I got a replacement quartz clock from Ecklers. I have the old one out and took the new one out to the car to test it. I hooked the orange wire to the back where the power connector is (the old one did not have this, but there was an extra wire/connector back there). When connected, it still did not do anything.
Am I hooking something up wrong, or do I need to wind it....
Thanks for the help!
Old Feb 17, 2004 | 04:59 PM
Cooter Tech's Avatar
Cooter Tech
Default Re: Clock installation question (iveka)
Dumb question, did you ground it?
Old Feb 17, 2004 | 05:09 PM
iveka's Avatar
iveka
Default Re: Clock installation question (Roger L. Gibbons)
The back of the clock only has the one connector on the back. I am not real good with wiring, so I am not sure how it needs to be grounded. Sorry for my ignorance when it comes to wiring.
Old Feb 17, 2004 | 06:25 PM
vettfixr's Avatar
vettfixr
The positive wire goes to the connector and the negative wire is grounded to the case. The grounding occurs naturally when the clock is installed on the bezel but if you're bench testing it you have to clip the negative wire to the case to ground it.
Old Feb 17, 2004 | 07:37 PM
iveka's Avatar
iveka
Default Re: Clock installation question (vettfixr)
Thanks for the advice. I'll give that a shot!
To Clock installation question
