Valve Cover Paint
Old Feb 19, 2004 | 09:40 AM
Stoge's Avatar
Stoge
Default Valve Cover Paint
On the L-82 valve covers, couldn't one just paint the whole thing black and then run the top through a belt sander a couple of times to take the paint off of the ridges? I got to looking at them the other day and it appears this is how they did it at the factory.
At any rate, what paint should I use?
Old Feb 19, 2004 | 10:12 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Valve Cover Paint (Stoge)
Yep, that's how you do it. I use lacquer, it shines real nice and dries fast.
Old Feb 19, 2004 | 11:00 AM
verskel's Avatar
verskel
Personally, I wouldn't use a belt sander but do it by hand.
Then you can go over it with "0000" steel wool for polishing.
I've been successful with spray-on engine enamel but I like Burners suggestion better. :yesnod:
Old Feb 21, 2004 | 03:16 AM
glen242's Avatar
glen242
Use a rag with paint thinner and carefully wipe the raised portions. I used VHT?, I think, black high temp. engine paint and it worked well.
To Valve Cover Paint
