T-top luggage rak
Old Feb 19, 2004 | 11:07 PM
kks74's Avatar
kks74
4th Gear
Default T-top luggage rak
Anyone out ther e seen a luggage that is made to hold the T-top panels?
Old Feb 19, 2004 | 11:08 PM
Stoge's Avatar
Stoge
Default Re: T-top luggage rak (kks74)
Yes. I believe the OEM racks were meant for this. Check with the 'vette parts vendors and Ebay...
Old Feb 20, 2004 | 09:38 AM
trw's Avatar
trw
You can convert the rack. Just drill and add nylon spacers with screws.
I have the instructions if you need them.
Terry
Old Feb 20, 2004 | 01:21 PM
coz72lt1's Avatar
coz72lt1
Try catalog companies like Ecklers or MidAmerica
Old Feb 20, 2004 | 01:30 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
The luggage and roof panel rack was a factory option only in 1977 (RPO V54). The luggage rack uses 8 bolts (as opposed to the usual 6) and has "pins" to hook up the T-Top holders. I've never seen the top holders offered by any of the usual sources (MAD, CC, ZIP ect.), but if you do a search (assuming the search function is working) there have been some previous trheads about these racks.
Old Feb 20, 2004 | 08:32 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: T-top luggage rak (6t9l4t6)
Bungee cords work well:cheers:
Old Feb 20, 2004 | 09:46 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: T-top luggage rak (AlwaysWave)
http://www.angelfire.com/extreme3/a.r.contracting/
I'm looking at this one when I have the $$. Wonder what speed they're safe up to??
Old Feb 20, 2004 | 10:23 PM
outrunm's Avatar
outrunm
St. Jude Donor '06
I have seen a lot of these lately, They are now being replicated. Basically, you are looking for a rack hat has "nubs" on the the center and outboard bars of the rack that will hold the mounting kit. I think the whole setup is about $300 and change. At least that's what I saw one going for at the Winter NCRS meet last month. The Eckler's part number is A2194 for the rack, and Part# 45913 for the t top carrier. Unfortunately, I opted for a stainless rack when I painted my '77 about 6 years ago, so my T-tops go in the storage compartment when they come off. (or they get left at home)
Old Feb 20, 2004 | 10:46 PM
trw's Avatar
trw
I think you can install them on either rack. I know I have them on a 6 hole rack.
But I drilled my own holes and installed the nylon spacers (pins) and screws.
Terry
[Modified by trw, 7:50 PM 2/20/2004]
Old Feb 20, 2004 | 11:37 PM
LiveandLetDrive
Default Re: T-top luggage rak (trw)
I believe the one I linked doesn't require the little nubs on the rack.
Old Feb 20, 2004 | 11:53 PM
outrunm's Avatar
outrunm
St. Jude Donor '06
Default Re: T-top luggage rak (RUXperienced)
I haven't been able to see it. "excessive bandwidth"
[Modified by outrunm, 4:54 AM 2/21/2004]
Old Feb 21, 2004 | 07:56 AM
Bobchad's Avatar
Bobchad
I've had them from Glenn for about two years. Nice product and a stand up guy. I've had the car up to at least 80 mph with them on the back of the car. The way they sit the wind goes over the top of them as it goes over the roof so they are affected by little, if any, lift.
[Modified by Bobchad, 9:00 AM 2/21/2004]
Old Feb 21, 2004 | 08:15 AM
Ganey's Avatar
Ganey
The factory system works well. Have run 100+ w/ them off for long distance on a trip to Calif. Arrived near deaf though.
Old Feb 21, 2004 | 09:25 AM
1FUNVET's Avatar
1FUNVET
Yeah what he said........
Is your back space decking full of other stuff?? :chevy
To T-top luggage rak
