edelbrock torker 2 intake manifold
I UNDERSTAND THAT THE TORKER 2 IS THE ONLY MANIFOLD THAT WILL ALLOW ME TO USE THE STOCK HOOD ON MY 73 BIG BLOCK. IS ANYONE USING THE TORKER? IS IT BETTER THAN STOCK?
Re: edelbrock torker 2 intake manifold (GRIZ73)
I use the torker 2 on my 69,427 stock hood o.k.,but clearance is poor.With a 770 holly avenger not much room for a good air filter. Use a Moroso drop base with a 2 1/2 accel filter,high flow K.and N extreme lid will not fit. A 73 might have more room though..Don't know about the LS-6 pancake sounds interesting.Another thing,it's a single plane,higher rpm power(5500+).I'd like to know the # of the LS-6 manifold :steering:
Re: edelbrock torker 2 intake manifold (blue427)
The LS6 intake is designed for rect port heads. I ran a Torker II on my '71 BB for a while. It cleared the stock hood, but only after I bought a 2.75" K&N filter vs. a 3" high standard size. Also, if you are using a Holley, you will need to run one without the choke horn. My 750 holley was starved for air. As soon as I switched to a carb w/o choke horn (I use a BG carb), the problem was solved.
This intake made very good mid range power, but I always had an off idle stumble that was hard to clean up. Part of it could be the BG carb, as I was still learning how to tune it-still am!
I still have my Torker II if you want to try it.
You have more clearance w/ the med. rise hood. W/ the II, run as much insulator/spacer (about 1/2") as you can W/O restricting carb intake. Leave at least 3/4" over vent tube.
