interior lights on..
Old Feb 20, 2004 | 12:39 PM
dreamn2's Avatar
dreamn2
Default interior lights on..
Putting in new weatherstrip last night, when I shut the door the interior lights came ON and will not go off. They never worked with the door switch before but would turn on with the headlight switch. Now I can't get them to go off. Suggestions?
Old Feb 20, 2004 | 01:35 PM
sb69coupe's Avatar
sb69coupe
Default Re: interior lights on.. (dreamn2)
Sounds like one of the hot wires on the switch is shorted to ground. Pull off the kick panels and remove the switches to check them out.
Old Feb 20, 2004 | 01:57 PM
dreamn2's Avatar
dreamn2
Default Re: interior lights on.. (sb69coupe)
Side Question:Why are there 2 contact switches on the door?
Old Feb 20, 2004 | 02:21 PM
Crash80's Avatar
Crash80
Go here.
http://iotech.no/corvette/index.htm
This guy has a ton of useful stuff including schematics on what you are trying to fix. It is for an '80 but I would imagine yours to similar. Best of luck.
Old Feb 20, 2004 | 02:37 PM
dreamn2's Avatar
dreamn2
Default Re: interior lights on.. (CVT4ME)
Great link, Thanks.
sb69coupe's Avatar
sb69coupe
The switch at fromt of the door is for the courtesy lights. The one at the rear is for the door ajar light and the optional UA6 anti-theft system.
Old Feb 20, 2004 | 02:43 PM
dreamn2's Avatar
dreamn2
Thanks. Looks like some tracing to do when I get home tonight.
Old Feb 20, 2004 | 03:33 PM
Crash80's Avatar
Crash80
I don't know if you saw the schematics section or not but if you didn't, check it out. It is smokin' for helping you locate wire, colors etc. Good luck!
To interior lights on..
