is the battery toast?
Old Feb 20, 2004 | 04:34 PM
munday's Avatar
munday
Default is the battery toast?
has 12+ volts but only get a clicking from the starter
Old Feb 20, 2004 | 04:51 PM
Gordonm's Avatar
Gordonm
Default Re: is the battery toast? (munday)
A fully charged battery should have around 13.5 volts. Check the voltage when you try to start it. If it drops way down the battery is probably toast or the selonoid is drawing to much power.
Old Feb 20, 2004 | 04:54 PM
Fevre's Avatar
Fevre
Check your ground connection, you should be able to crank it with 12 v.
Old Feb 21, 2004 | 09:41 PM
sjr1971's Avatar
sjr1971
Batteries are strange. They will show good voltage even when they are almost dead. The only way to check for sure is to go thru each cell with a hydrometer to register the specific gravity. A dead cell ='s a dead bat. This is a dying art 'cause for 80 bucks or so you can shot-gun the bat.
Old Feb 22, 2004 | 01:47 AM
The Dude's Avatar
The Dude
Default Re: is the battery toast? (sjr1971)
:withstupid:
Hydrometer is just about fail-safe.
To is the battery toast?
