Re: Post Your XE 262 Powered Numbers Here (Eddie 70)
I don't know what the HP numbers are but it runs consistent 8 flats with a best of 7.991 @ 85 -87 mph in the eighth. That's a mid 12 quarter. combo is:
383, SportsmanII's, Perfomer RPM, Q-Jet, gapless rings, 9.2:1 compression, Hooker sidepipes, Accel 300+ ignition and of course XE262 hyd flat tappet.
Re: Post Your XE 262 Powered Numbers Here (79VetteMike)
:iagree: I am helping another forum member put together a similar motor with AFR 180 heads. We are hoping for around 380 to 400 at the flywheel when tuned correctly.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: Post Your XE 262 Powered Numbers Here (Gordonm)
Any ideas where I should look to find some of the lost power. I feel like my carb may be some of the problem. It does have a small stumble when you just touch the gas.
