Tach Problems... Final Word
Old Feb 22, 2004 | 11:15 PM
VolVette's Avatar
VolVette
Default Tach Problems... Final Word
My '75 Corvette's Tachometer quit working about 6 months ago. I read the archived threads and am uncertain how to troubleshoot because there seem to be conflicting opinions about whether the circuit board or tach filter is the usual culprit.
I prefer to not have to get in the dash and replace the circuit board, if it's not neccessary. But how can I test to see whether the circuit board is the problem or the filter?
I appreciate all your help!
Stephen
Old Feb 22, 2004 | 11:48 PM
mrvette's Avatar
mrvette
Default Re: Tach Problems... Final Word (VolVette)
Just jumper out the tach filter, hook it up directly, and see if the thing works....
you will get some erronious indications, but if the tach is working the needle will move more or less normally.....
if so, replace the filter, if not, the tach is bad.....
if you need the filter....look/search here for a schematic and make one up....
GENE
Old Feb 23, 2004 | 07:21 PM
VolVette's Avatar
VolVette
Default Re: Tach Problems... Final Word (mrvette)
Thanks for the post!
There were some who posted saying that they bypassed the filter with no improvement, figured it was the circuit board and replaced it only to find that the filter was the problem. Can anyone else validate this?
Thanks,
Stephen
Old Feb 23, 2004 | 07:40 PM
Resto75's Avatar
Resto75
I have a problem with my tach also. It works but reads too high. I don't have a tach filter that I can find, so I am interested in any info on the subject too.
Old Feb 23, 2004 | 11:32 PM
Fleetwood's Avatar
Fleetwood
As mentioned you can bridge out the tach filter,if you are still having problems it's not the tach filter.By bridging the filter you are in effect having a wire run from the distributor direct to the tach.You may then need to replace the circuit board.
Neil.
Old Feb 29, 2004 | 11:36 AM
willieo's Avatar
willieo
2nd Gear
Default Re: Tach Problems... Final Word (Fleetwood)
Fellow C3'ers I too have wrestled with this. I have some insight:
If your tach is not working at all:
1. test connections using ohm meter and see if you get a slight change from the wire that is coming from distributor (usually brown). Make sure the connection is good no green/rust or deterioration. Mine was OK.
2. More than likely as in my case I had to replace the tach board. But that wasn't it. As I got the thing to work it was way off.
If your tach is working and bouncing around like crazy or it reads too high you may need to do one or all of the following:
1. Pull needle off and reset using engine analyzer to detect proper rpm and then place needle back on.
2. add noise suppressor (home-made) capacitor. You will need this if you experienced the same syptoms that I did which was erratic tach reading and at 2000 rpm's the tach went back down to 0. The tach sweep should be a smooth as your engine accelerates. If you need the details I will send..It is about 8$ worth of radio shack parts and if you have a soldering iron you're golden.
Hope this helps,
Willieo
Old Feb 29, 2004 | 03:44 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Here's a pic of the tach filter schematic if needed.
Good Luck!
:seeya
To Tach Problems... Final Word
