Gas Cap/Tank Question
Old Feb 23, 2004 | 10:41 AM
pingdashf's Avatar
pingdashf
Default Gas Cap/Tank Question
I am looking at replacing my gas tank cap. Its a pain to open and close, and many times I've ended up with a cut to the bone on my finger because when it does finally pop lose I end up running my finger across the underside of the lid. That and it is starting to rust a little.
I could easily buy a replacement cap, but how do I know if the cap is the problem, or if the filler neck seal is the problem. Or is this just the way C3 Vette gas tanks are and I need to get a pair of leather gloves to remove the cap so I dont cut myself?
If the Filler neck is the problem, how hard is that to replace?
Old Feb 23, 2004 | 12:52 PM
72GACRZR's Avatar
72GACRZR
Default Re: Gas Cap/Tank Question (pingdashf)
My '72s gas cap is tight, but not a problem. I sometimes have to push down on it to get it loose.
Old Feb 23, 2004 | 03:27 PM
markdtn's Avatar
markdtn
Default Re: Gas Cap/Tank Question (72GACRZR)
:iagree: Mine is tight, but not a problem. If the neck is the problem you will probably break off all the bolts that hold it on. I would start with the cap. They are still available from GM.
Old Feb 23, 2004 | 03:40 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Gas Cap/Tank Question (markdtn)
I bought a new cap a few months ago. I don't remember the price, but it was not much. Why don't you get one and try it? :)
Old Feb 23, 2004 | 05:44 PM
pingdashf's Avatar
pingdashf
Default Re: Gas Cap/Tank Question (OHSIXX)
They are only $25 through zip. so I'll try that out. I also need to get a 74 gas tank decal since mine is not original. I can't find a cap for a 74 though.
To Gas Cap/Tank Question
