Rocker Panel Repair Kit??
Old Feb 23, 2004 | 12:29 PM
VettePower's Avatar
VettePower
Default Rocker Panel Repair Kit??
Anyone ever bought the rocker panel screw insert repair kit? I was wondering how you put in those new brass inserts? And how you remove the damaged old inserts?
Thanx in Advance :flag
Old Feb 23, 2004 | 08:53 PM
CF6873's Avatar
CF6873
Default Re: Rocker Panel Repair Kit?? (VettePower)
To remove the busted and rusted old nuts you will have to grind them off. I haven't used the repair kit that you mentioned but I used jack nuts to repair mine. They fit in the holes and then you insert a bolt and tighten it. This compresses the jack nut until it becomes tight in the hole. I would imagine the brass ones will be similar. Craig :chevy
Old Feb 23, 2004 | 09:03 PM
Jb3778's Avatar
Jb3778
Be REAL careful with the repair kit, the brass insert breaks easily. Once I figured this out I used lock-tight and just snugged them up. It's a good product and does a good job. I believe I bought mine from Zip. Jim
Old Feb 24, 2004 | 12:14 AM
72 RAY's Avatar
72 RAY
Default Re: Rocker Panel Repair Kit?? (Jb3778)
:iagree:
Old Feb 24, 2004 | 04:42 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I cut off any remaing screw heads then drilled out the screw. I got mine from Ecklers, simply follow the directions. I like the lok-tite idea mentioned above. :thumbs:
To Rocker Panel Repair Kit??
