My car will start up fine when it is cold or slightly warm, yet when it is hot(over about 120) it will not start again. All it does is turn over about two or three times. I've took all the pro-cautions that I can. I've got aluminum heat wrap over the starter and on all of the ignition wires. What else can I do? It is driving me bonkers!!! Also the starter is new. My last two I actully broke the casting on the starters. Help!!!! :cuss
Re: When engine hot, it won't start... ('74BigBlock)
You might want to install a new mini starter, they are sold on Ebay and have more clearance from heat and seem to work well, I just purchased one recently because I needed more clearance from the headers.....
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Re: When engine hot, it won't start... (73jst4fun)
I would suggest a gear reductive starter and a good heat shield. I'm sure there will be better suggestions, but this is what has worked for friends of mine in the past.
Are you running headers with it? if so you may want to either have them coated or wrapped to keep the heat down. I've never had a problem with my starter with the Jet Hot coated headers, a mini starter as suggested would also help and reduce weight at the same time.
Yes, I do have some Hooker Super Comps on it. Yet it doesn't seem to get much hotter than when I had the Orignal Manifolds on. Yet I do like the starter above alot. Not a bad price either. About 170 bones from GM parts direct. With the amout of cash I've spent on starters I could have got it along time ago!! :thumbs:
I have a Optima with 720 CCA so I know it is enough. I guess I've just always thought that a OEM starter would do the job of starting. Yet I suppose with a 10.5 to 1 bored out BB it might come up a little short. :cuss :cuss :cuss I'm just going to go kick my on rear. :mad
Something is not right with your starting system. I have Hooker Super Comps on a hot small block and I can start my car at over 200 degrees the first time with very little cranking.
Before you buy an aftermarket starter have another look through your system. For instance, I had a buick Grand National that wouldn't start when it got the slightest bit of heat. After replacing the starter and solenoid with no improvement I started checking the wiring. Someone had replaced the wire from the starter switch to the coil with a smaller gauge wire for a starter kill switch. That wasn't the worst part...they had just twisted the wires together and taped over it! The solenoid wasn't getting enough juice when any amount of heat entered the system. I ripped out the extra wire and soldered the new connections, never had another problem.
My point is that there are a lot of people on this forum with wild big blocks and stock-style starters that work. If I were you I'd check grounds, battery cables, etc before replacing the starter.
Jeff
I'm surprised that no one has mentioned vapor lock yet. It's caused by having your fuel line too close to something hot. If the fuel line gets too hot then a vapor bubble is formed and blocks fuel to the carb. Have a look at the routing of your fuel line and see that its not too close to your headers or heads, etc. You can buy a fuel line wrap at Jeggs or Summit. This would be worth a look before messing with your starter again. Let us know what you find out. :cheers:
Also check the timing & make sure the balancer ring hasn't slipped. If the timing is to far advanced it makes the engine difficult to crank. Bring #1 up to TDC and check out where the timing mark is located. Had a similar problem with a SBC and the fix was to simply set the timing correctly after replacing the balancer.
I know what youre talking about.
When hot the engine will crank but not like normal. Kinda just turns over right? Like its not going to fire or its kinda "Boggy" Am I close?
Anyway, I had the same issue. Sure I changed starters, Knee jerk reaction. It didnt help.
As no_radio suggested, check your grounds/wiring.
Then make sure your fuel isnt boiling in the line. Vapor Lok.
Sorry but vapor lock will not cause the starter to only crank over a few times, it will cause the eng to not start but it won't cause the symptons desc in the org post.
Before you do the starter thing, take 70BBvert's advice. My 78 had the same problem. Fixed it with a timing adjustment! Back the timing off a couple of degrees and give it try. If that seems to work but your timing seems too low then check for a slipped balancer.
Just make sure that you have enough cold cranking amps in the battery. This one area where "more is always better" with any engine and quit often overlooked as being OK because it starts when cold. None of my engines have fancy starters and heat wraps everywhere to prevent so called heat "soak" starters and most are header equiped and at least 11-1 compression. Once running everything gets hot and should run perfectly. But you do need sufficient cranking power to turn it over. A engine in "proper tune" will not experience hot cranking problems with a strong enough battery. :D
