One step foward, two steps back......bellhousing cracks
Old Feb 24, 2004 | 09:49 AM
70BBvert's Avatar
70BBvert
Default One step foward, two steps back......bellhousing cracks
I cleaned & glass beaded the bellhousing this weekend to get ready for paint. After it was good & clean I found two small stress cracks that will need to be welded. Anyone ever had this done on a factory aluminum bellhousing.
On this picture you can see the crack at the bottom, approx 2" long extends through the case.
On this on the crack is at the top on the mounting surface:
Thanks - click on the pics to enlarge
Jim
Old Feb 24, 2004 | 10:01 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default Re: One step foward, two steps back......bellhousing cracks (70BBvert)
dayum...not a good thing..
Don't have a definitive answer, but I know that when our guys are welding a stress crack, they always drill a small hole at the end of the crack to stop its progress, then weld...
Old Feb 24, 2004 | 10:28 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
That sucks :nonod:
Old Feb 24, 2004 | 10:32 AM
SCCACFC's Avatar
SCCACFC
Default Re: One step foward, two steps back......bellhousing cracks (GrandSportC3)
You can TIG alum. and it will be fine. About half of the stock bellhousings we see here are cracked and used ones are getting harder to find.
Old Feb 24, 2004 | 11:16 AM
78 Vette's Avatar
78 Vette
Default Re: One step foward, two steps back......bellhousing cracks (SCCACFC)
That sucks but It can be fixed :iagree:
Old Feb 24, 2004 | 11:43 AM
bertmeister's Avatar
bertmeister
Default Re: One step foward, two steps back......bellhousing cracks (78 Vette)
I had one welded for an old camaro that I owned. Any good weld shop should be able to fix you up.
:cheers:
Old Feb 24, 2004 | 04:25 PM
70BBvert's Avatar
70BBvert
Default Re: One step foward, two steps back......bellhousing cracks (bertmeister)
Thanks Guys - gota couple of leads from the body shop we use on our fleet cars. I'll get a couple of estimates tomorrow.........
To One step foward, two steps back......bellhousing cracks
