Lowering questions
Old Feb 24, 2004 | 01:00 PM
82Red's Avatar
82Red
Default Lowering questions
I would like to lower my vehicle approximately 2" on the Front and Rear for show.
On the REAR:
Could someone tell me if 8" long spring bolts would work, or do I need 10"?
Also, when replacing the rear spring bolts, is it absolutely necessary to replace the stock strut rods with adjustables as well?
On the FRONT:
I have seen the street/slalom springs that claim to lower the vehicle approximately 1". Can I go lower any lower than that?
Thanks!
RON
Old Feb 24, 2004 | 04:08 PM
American Boy's Avatar
American Boy
Default Re: Lowering questions (82Red)
For 2" you'll surely need the 10" long bolt for the rear. Anyway, they are 2 or 3 $ more and you must cut them after finding the proper lenght that you need as a safety mesure.
The rear strut rod should be change in order to keep the camber close to spec. I don't know if just the ajdustable strut will give you enough. Maybe the smart strut would do it.
As for the front, you could just cut coils of your spring. I know that 3/4 of a coils in the open end drop the front for about an inch.
Good luck
Stephan
