What does your oil temp gauge read??
Feb 24, 2004 | 03:59 PM
I would like to know what your oil temp gauge reads when driving on the highway at speeds around 60 - 70 mph for longer periods of time? :cheers:
Feb 24, 2004 | 04:19 PM
Re: What does your oil temp gauge read?? (Pauld)
if i can remember back to last summer....usually a bit higher than the engine temp...200-210-220...
Feb 24, 2004 | 07:29 PM
St. Jude Donor '03,'11
about 35-40 psi
Feb 24, 2004 | 09:43 PM
80
Feb 25, 2004 | 03:30 AM
St. Jude Donor '09
Re: What does your oil temp gauge read?? (jacobsed)
Remember, I live in the southwest part of Arizona. (KILLER SUMMER HEAT)
I usually run 220 to 250 easily in the summer, and if I push it, I see above that. But I try to keep it changed and not push it too much for very long at the extremes... :mad
Feb 25, 2004 | 03:39 AM
Mine read between 240-260 degrees........then I wrapped the header with heat shield and put heat shield around oil filter....and temps dropped about 20 degrees....It appears the header was too close to the oil filter and cooking the oil before returning to the engine. :steering:
Feb 25, 2004 | 03:41 AM
Cruise-In IV Veteran
Re: What does your oil temp gauge read?? (8T1-7T9 BIONIC VETTE)
0
Feb 25, 2004 | 03:49 AM
ok, thanks guys, mine reads around 240 and I was concerned that was hot. That has put my mind at rest. :cheers:
Feb 25, 2004 | 04:37 AM
St. Jude Donor '09
Re: What does your oil temp gauge read?? (Corz)
Thats your own fault... :lol: :lol: :lol:
Feb 25, 2004 | 10:29 AM
Re: What does your oil temp gauge read?? (Desertdawg)
A good rule of thumb on oil TEMP. is 20 deg. above the water temp.
Feb 25, 2004 | 12:43 PM
Re: What does your oil temp gauge read?? (SCCACFC)
Mine runs about 220 and usually stays right around that but it takes a while to get there.
Feb 25, 2004 | 06:47 PM
Re: What does your oil temp gauge read?? (CHEESERAL)
Mine runs at 40 road and 51 at track(hi rpms). Normal for my 82. :smash:
While my cooling is at 200 road and 230 at the track (hi rpms). :smash:
IRON 82 :auto: :steering:
Feb 25, 2004 | 09:09 PM
Hey guys - it was oil TEMP - not oil PRESSURE!
Feb 26, 2004 | 01:03 AM
St. Jude Donor '09
Re: What does your oil temp gauge read?? (Larry82)
Yeah, what he said.... :lol: :lol: :lol:
Feb 26, 2004 | 02:02 AM
Quote:
0
:rofl: :rofl:
Feb 26, 2004 | 06:57 AM
Mine reads 0 as there is still 4 feet of show here. I ahve been told that is should run 20 degrees hotter than your water temp. The reason I have a oil temp gauge is to keep a eye on my crank bearings. IF your oil temp jumps by 30-40 degrees your bearings are going. Good Luck
