From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: 1980 sunvisor removal (AGVI)
I used a large phillips screwdriver and a hammer. A punch would work as well. just center the tip on the end of the arm sticking through the clip. Give it a couple good wacks and watch out for the clip and spring to take off in the air as the visor falls in your seat.
Hey Quinn, I am having the opposite problem. My drivers side visor will fall in my lap if the road gets a bit rough. I need to figure out how to get mine to stay in the air. So from what I am reading here, there is supposed to be some sort of retaining ring? I bet mine is gone, hince my problem.
Looks like this...fit over the visor arm inside ...
You know, I was going to ask if someone could post a pic but decided against it thinking "Who would have a pic of that?" Lo and behold, Avette4me pulls through. Thanks a ton for the pic. I was just looking through Ecklers and seeing if I could see anything there that would help me out. Their picture is so tiny I couldn't tell what I was looking at. Thanks again!
