Water pump question
Old Feb 24, 2004 | 08:41 PM
Marks69BB's Avatar
Marks69BB
Default Water pump question
How do you tell if it's about to go? Does it leak through the weep hole? If so, where is it? I've seen what I think are coolant spray marks on my heater hose and t-stat housing and have checked all of my hoses and clamps and everything's tight. What gives? :confused:
Old Feb 24, 2004 | 09:26 PM
wombvette's Avatar
wombvette
Default Re: Water pump question (Marks69BB)
The weep hole is under the housing in line with the shaft. Yes this is what usually shows up first. Sometimes the bearings will fail. You should hear that or see slop in the shaft.
