differential rebuild/exchange questions
Old Feb 25, 2004 | 03:53 PM
fjetb's Avatar
fjetb
Default differential rebuild/exchange questions
1. I have a 71 vette...auto...my differential has a whine that gets louder as I cross 50mph...if I back off the gas the whine stops...I've been told that it probably is the pinion bearing...does that sound right to you guys?
2. If that is the problem, should I have someone local do it, or just buy a rebuilt one/exchange from one of the online sites?
3.If I do the exchange/rebuilt route online, which sites are the best for cost/quality?
4. Anyone use vetteperfect for a rebuilt differential? They seem to have the best price I could find.
Thanks.
Old Feb 25, 2004 | 05:16 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: differential rebuild/exchange questions (fjetb)
Thanks.
I had mine rebuilt by Van Steel (who is a forum vendor and does exceptional work)
Old Feb 25, 2004 | 05:34 PM
GTR1999's Avatar
GTR1999
Sounds like a front pinion bearing. A good shop can rebuild these as can Van Steel,Zip,Ikerds, or Bairs. What you should do is ask your local guys what they do for a rebuild,other then bearings and seals do they go into the posi, paint them, do any kind of performance work. Also the side yokes are not usually part of the job, they are extra.
Good luck,
Gary
Old Feb 25, 2004 | 07:30 PM
fjetb's Avatar
fjetb
Default Re: differential rebuild/exchange questions (gtr1999)
Thanks guys, good advice.
Old Feb 25, 2004 | 08:53 PM
jdcrvt's Avatar
jdcrvt
Hi guys, Im wondering the same. I was just planning to ship it off to Van Steel. I have the car totally torn down and am now putting it back together. I noticed that ithe rear-end is leaking oil so I am just going to have the whole thing rebuilt. Does anyone see any difference between Van Steel or Bairds? Also, will UPS be able to ship it. As you al know. it weighs a ton. :flag
Old Feb 25, 2004 | 11:45 PM
stinky's Avatar
stinky
Default Re: differential rebuild/exchange questions (GrandSportC3)
GS...what exactly did you have done, thinking about using them as well but like to know what was done. thx
Old Feb 26, 2004 | 06:56 AM
Gary79's Avatar
Gary79
Default Re: differential rebuild/exchange questions (stinky)
I had my 79 diff rebuilt locally. i took it out, bought the parts and handed them the diff to do the work. breakdown, $200 on rebuild kit, $200 in rebuilt axle yokes from Bair's, $200 labor, reused same gears, total $600.00 all :)
Old Feb 26, 2004 | 07:19 AM
Roadster71's Avatar
Roadster71
Has anyone used VetPerfect? The $375.00 price seems low. http://corvetteperfection.com/corvetteperfection001.htm
To differential rebuild/exchange questions
