MSD Tach Drive Distributor
Old Feb 25, 2004 | 05:36 PM
thebruce's Avatar
thebruce
Default MSD Tach Drive Distributor
Anyone have one? I want to make sure it's going to fit before I buy one. If it doesn't I suppose I'll go with Pertronix and a MSD box at some point.
Any thoughts would be appreciated.
:flag
Old Feb 25, 2004 | 05:45 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: MSD Tach Drive Distributor (thebruce)
I have one. I think it is the best distributor to come along since the K66 ball bearing unit Chevy installed. The MSD also uses ball bearings and is very high quality.
Chuck
Old Feb 25, 2004 | 08:02 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: MSD Tach Drive Distributor (Chuck Harmon)
The dist is worth it :thumbs:
Old Feb 25, 2004 | 08:05 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
MSD tach drive is in my car! The only thing is you need a MSD box to run the distributor. No fitting problems and it works flawlessly.
Old Feb 25, 2004 | 08:59 PM
blue427's Avatar
blue427
call MSD and see if they have a ready to run tach drive dist.then you won't need the box :steering:
Old Feb 25, 2004 | 09:05 PM
thebruce's Avatar
thebruce
Default Re: MSD Tach Drive Distributor (blue427)
Thanks to all for the input.
Blue427, not sure what you man by 'ready to run.' Does MSD make distributors that don't need MSD boxes and work with regular coils? That would be a nice way to spread the cost of this little enterprise out a little bit. :cheers:
Old Feb 26, 2004 | 02:09 AM
AV8RSVT's Avatar
AV8RSVT
I emailed MSD and they said they currently do not offer A tach drive distibutor that does not require A box to run. READY TO RUN :mad
Old Feb 26, 2004 | 02:14 AM
Chuck Harmon
Default Re: MSD Tach Drive Distributor (AV8RSVT)
The K66 had to have a box to run too. Think of it as a replacement for the K66. Old distributors can be rebuilt, but they were never on par with the K66 or the new billet MSD's.
Chuck
Old Feb 26, 2004 | 08:38 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I would love to have a later distributor but I don't want to have to add a box. Is there one out there or would I just be better off rebuilding mine next winter?
Old Feb 26, 2004 | 09:23 AM
dash8's Avatar
dash8
Default Re: MSD Tach Drive Distributor (Eddie 70)
best thing i've done for performance. even with the box... :thumbs: :thumbs:
and it fits under the ign. cover.. :cheers:
[Modified by dash8, 9:25 AM 2/26/2004]
Old Feb 26, 2004 | 11:12 AM
carriljc's Avatar
carriljc
I had one, actually still do, ran it for about 8 years. Ran so well I never looked inside it. When I finally did (after ~8 years) I noticed that it was quite corroded. This is a car that spends most of it's time in a garage...I was quite surprised by that. Wd40 that puppy just to minimize corrosion. Cannot say anything negative about how it ran though.
IF you want to consider other options, you might be better off getting an electronic tach from a 75-77 and then getting one of many HEI type tachs. You can get stand-alone tachs and your choices are extensive. I wish would have done this to begin with.
Old Feb 26, 2004 | 11:26 AM
Robert N's Avatar
Robert N
Default Re: MSD Tach Drive Distributor (carriljc)
Chuck, or anyone that knows, how big is the MSD box compared to the K66 amp?
My K66 is long gone and rather than replace it, I will probably just run the MSD setup. WIll the MSD box fit in the same location as the K66 amp?
Old Feb 26, 2004 | 12:10 PM
thebruce's Avatar
thebruce
How much of a difference is there between MSD and HEI?
I originally planned on swapping tachs when I pulled the dash a while back, but I didn't. What a huge mistake. Should I go ahead and schedule a weekend to pull the dash and swap tachs, then just run a non-tach drive distributor and either HEI or MSD?
Old Feb 26, 2004 | 12:29 PM
AV8RSVT's Avatar
AV8RSVT
Mallory does have the elect. stand alone unit ~$365. magnetic breakerless or unilite. These are mech tach drives. coil seperate from the distributor just like the MSD. I called A local shop (specialize in distributors) He recommended the magnetic breakerless over the unilite. :crazy:
Old Feb 26, 2004 | 03:31 PM
theandies's Avatar
theandies
I have one and love it. It is very user friendly. Get a Digital box or a 6AL which have rev limiters in them. It is nice knowing that you can tach the hell out of your car and it is protectected by the limiter IMHO.
Old Feb 26, 2004 | 08:34 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Check the sig, not MSD, but has performed flawlessly for over a year.
Old Feb 26, 2004 | 09:26 PM
TeenagerWith74Vette's Avatar
TeenagerWith74Vette
Default Re: MSD Tach Drive Distributor (74 vert)
I'm no longer using my MSD Tach Drive Dist. It was rebuilt by MSD about a year ago with all new internals and cap.
Shoot me an email or PM if anybody wants to buy it.
Jay
To MSD Tach Drive Distributor
Old Feb 26, 2004 | 09:30 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I've been wondering...is the factory mechanical tach more accurate than the big $$$ electronic tachs from Auto Meter?
Dep
[Modified by DJ Dep, 8:30 PM 2/26/2004]
Old Feb 27, 2004 | 03:10 AM
Chuck Harmon
Default Re: MSD Tach Drive Distributor (DJ Dep)
After seeing how much tach lag my ZO6 has in 1st and 2nd gear, I think the only solution is to get a good shift light. Something that doesn't stick out in ricer fashion.
Chuck
Old Feb 27, 2004 | 09:12 AM
MassVette's Avatar
MassVette
I got the Mallory tach drive Unilite on the '67. No vacuum advance, and burnt the coil and module up by accidentally leaving the key on- ran OK other than that-
:yesnod:
