distributer noise
Old Feb 25, 2004 | 08:43 PM
madvette74's Avatar
madvette74
Default distributer noise
posted February 25, 2004 08:36 PM
i heard a clanking noise at idle, and goe's away when engine revs, i checked the flex plate, checked the rockers, it sounded like it was coming from the distributer cap, so i took the cap off (THIS IS HEI)and you can lift the rotor upwards (it clanks) and when you wiggle it it makes a clanking sound, loud.. this is the sound i believe i hear, i dont think a rotor should move that freely upwards or by rotating it back and forth... is this true, could i have distributer problems?
Old Feb 25, 2004 | 10:23 PM
wombvette's Avatar
wombvette
Default Re: distributer noise (madvette74)
Rotors typically have motion. The rotational motion is the fly weights for the centrifugal advance. Some up and down is also normal.
Old Feb 26, 2004 | 12:38 PM
Paul L's Avatar
Paul L
Shim the drive gear down to 0.007" to get rid of the up-and-down movement. The distributors I have rebuilt have about 0.018-0.025" initially.
To distributer noise
